Старый 25.06.2010, 02:05   #1
paruvella: Adding Submenu and MenuItems to Ax-Menus using X++ code
Источник: http://paruvella.spaces.live.com/Blo...4DB0!540.entry
In this example I am going to illustrate how we can add the Menu items to the Menu’s using X++ code.
For this example, I am using form called InventParameters.
For this form I am creating new Display Menu Item, and the same menu item I am going to place in Invent menu.
Inventory Management à Setup à My Menus à My Invent Parameters
The above marked Submenu and Menu item are added to Invent Menu by using following X++ job.
static void AddSubmenuNItemstoMenu(Args _args)
    #AOT
    TreeNode        treeMenuItem;
    TreeNode        treeDisplayMenu;
    TreeNode        treeMenus;
    Menu            treeMenu, treeMenu1, treeMenu2;
    str             MenuName = "MyInventParameters";
    MenuFunction    menuFunction;
    treeMenuItem        =   TreeNode::findNode(#MenuItemsDisplayPath);
    treeDisplayMenu     =   TreeNode::findNode(#MenuItemsDisplayPath + "\\" + MenuName);
    treeMenus           =   TreeNode::findNode(#MenusPath);
    if(!treeDisplayMenu)
        treeMenuItem.AOTadd(MenuName);
        treeDisplayMenu = treeMenuItem.AOTfindChild(MenuName);
        treeDisplayMenu.AOTsetProperties("PROPERTIES\n Object  #" + "InventParameters" + "\n  Label  #" + "My Invent Parameters" + "\n ENDPROPERTIES\n");
        treeDisplayMenu.AOTsave();
        treeMenu = treeMenus.AOTfindChild("Invent");
        treeMenu1 = treeMenu.AOTfindChild("Setup");
        //treeMenu2 =  treeMenu1.AOTfindChild("Parameters");
        menuFunction = new MenuFunction(MenuName, MenuItemType::Display);
        treeMenu1.addSeparator();
        treeMenu1.addSubmenu("My Menus");
        treeMenu2 = treeMenu1.AOTfindChild("My Menus");
        treeMenu2.addMenuitem(menuFunction);
        treeMenu.AOTsave();
        print "New Menuitem is created under Invent menu";
        pause;
In the above example I had used Menu class, instead of Treenode class for adding the Submenu and Menu items to the Menus of Ax.
After the above job is executed, you can find a new Display Menu Item at the following path
AOT à Menu Items à Display à MyInventParameters.
We can observe new Sub menu and Menu Item under Invent Menu also.
AOTà Menusà Inventà Setupà My Menusà My Invent Parameters.
Часовой пояс GMT +3, время: 19:24.
