Старый 19.04.2010, 09:05   #1
kamalblogs: Converting a System.Xml.XmlDocument to XML type in Dynamics ax
Источник: http://kamalblogs.wordpress.com/2010...cument-to-xml/
When interacting with .Net assemblies mostly  Xml is used to send/receive outputs from the external system. Here is a code snippet that tells how to convert a System.Xml.XmlDocument to a Xml string in Ax which you can use for further processing by classes like XmlDocument…
//CLR Objects
System.Xml.XmlDocument document;
System.Xml.XmlTextWriter textWriter;
System.IO.StringWriter   stringwriter;
//X++ Objects
Xml                      Xml
//call to the .Net assembly that returns a XML
document    = processINput(...argument..)
stringWriter = new System.IO.StringWriter();
textWriter   = new System.Xml.XmlTextWriter(stringwriter);
document.writeTO(textWriter);
//Converted to Ax Xml format here
xml        = stringWriter.ToString();
Ошибка бизнес-процесса Tarasov E Dynamics CRM: Разработка 9 18.02.2010 14:02
Часовой пояс GMT +3, время: 06:02.
