CRM Programmer: Passing parameters between MS CRM plugins
Источник: http://crmpro.blogspot.com/2009/11/p...en-ms-crm.html
============== I was needed to pass a variable from one plugin to another. If you have a two plugin at pre and post stage registered for on entity, then you can use a SharedVariables context property. But, if every plugins is a different assembly, and they are registered for a different entities... So, when the first plugin is firing, the second, which is starting after that, needed to know some information for redirecting it logic to another way. I had created some common assembly with helper methods and called it "Helper". Then I had created a static class with static variable and had put the value into it, at the first plugin execution runtime. In the second plugin I just get the value from the static common variable. And nothing about read\write DB operations. Helper assembly. namespace Helper { public static class Keeper { private static bool _UpdateOppAfterHistory = true; public static bool UpdateOppAfterHistory { get { return _UpdateOppAfterHistory; } set { _UpdateOppAfterHistory = value; } } } public class OpportunityHelper { ... } } First firing plugin code Keeper.UpdateOppAfterHistory = false; OpportunityHelper.CreateOpportunityHistory(Opp,crmService); // removing the flag to the back Keeper.UpdateOppAfterHistory = true; Second firing plugin code // common shared variable analysis bool UpdateOppAfterHistory = Keeper.UpdateOppAfterHistory; if (UpdateOppAfterHistory) { ... } Источник: http://crmpro.blogspot.com/2009/11/p...en-ms-crm.html
