Старый 08.08.2009, 10:05   #1
gatesasbait: Logging independently of transaction scope by using a separate thread in Dynamics AX (deux)
Источник: http://gatesasbait.spaces.live.com/B...B9F5!498.entry
Good evening
Michal Kupczyk from this thread on the Microsoft communities proposes a much better way to log independantly of transaction scope in Dynamics Ax than what I had originally proposed here. Instead of using a separate thread to log, is uses a UserConnection object.
In addition to being simpler, it also has the added value of working from within batches. Batches it seems don't support multithreading.
void method()
    UserConnection conn = new UserConnection();
    yourLogTable = null;
    yourLogTable.setConnection(conn);
    ttsbegin;
    yourLogTable.Log = 'This is tts-independent log';
    yourLogTable.insert();
    if (some_error)
        throw Error('Error in processing');
    ttscommit;
gatesasbait: Logging independently of transaction scope by using a separate thread in Dynamics AX Blog bot DAX Blogs 0 27.05.2009 23:16
Developer for Microsoft Dynamics AX Certification Roadmap Blog bot DAX Blogs 1 13.05.2009 16:17
Inside Dynamics AX 4.0: Transaction Semantics Blog bot DAX Blogs 0 31.10.2007 23:40
Часовой пояс GMT +3, время: 01:40.
