Старый 10.06.2009, 20:05   #1
palleagermark: Dialog error when adding batch tasks to a batch job
Источник: http://palleagermark.blogspot.com/20...-tasks-to.html
If you enter a new batch task to a batch job manually, AX might not initialize the Parameters dialog properly.
AX call unpack of the task class, with the contents of the Batch.Parameters field, but since we are creating a new entry to the table this field is empty.
What AX should do, and what RunBase normally does, is then to call initParmDefault of the task class to initalize it with for example a base query.th for example a base query.
Here is the code to insert in \Data Dictionary\Tables\Batch\Methods\showDialog in order to fix this issue.
Replace:
runClass.unpack(this.Parameters)With:
// As RunBase normally would do, we need to
// call initParmDefault here, if there are no
// values to unpack
if (!runClass.unpack(this.Parameters))
runClass.initParmDefault();
axaptapedia: RunBaseBatch Blog bot DAX Blogs 0 04.04.2009 22:05
axaptapedia: RunBaseBatch Blog bot DAX Blogs 0 31.03.2009 06:06
palleagermark: Adding new financial dimensions to AX Blog bot DAX Blogs 1 17.02.2009 13:03
axaptapedia: Batch processing Blog bot DAX Blogs 0 29.01.2009 17:05
Часовой пояс GMT +3, время: 10:19.
