Старый 09.01.2009, 18:05   #1
axcoder: PowerShell + Ax
Источник: http://axcoder.blogspot.com/2009/01/powershell-ax.html
Just added a small article to axaptapedia about administering Ax with PowerShell.
Старый 09.01.2009, 18:05   #2
axaptapedia: PowerShell
Источник: http://www.axaptapedia.com/PowerShell
Summary: /* Something like SQL */
PowerShell is a brand new command line interface for Windows.
Here are some information for administering Dynamics Ax with PowerShell
PSh has some advantages such as
*object oriented interface between commands
*using Microsoft .NET framework (so, I think, in can use business comnector)
*graphical shell
== Hand grenade instead of sniper rifle ==
If you use Windows Explorer, you can find some new abilities to work with groups ob objects. Unlike cmd.exe, PowerShell can work with object of different nature same way.
For example, here is a command which stop all AOSes
spsv aos*
where spsv is commandlet for stopping services, aos* is a mask for all services which have name starting with string "aos"
== Fire and forget ==
Sometimes I need to start aos after deltion of application indexes. When I do it with "services" control panel applet, it waits for a while than in outputs a messages, saying that service start takes longer than expected and stops to monitor service starting.
That how I do it wth PSh:
[[Image:Powershell.png]]
* I enter "sasv aos`$*1done"
* this command
** starts the service
** wait while it starts
** informing me about service is running
Where
* sasv - the alias for the Start-Service commadlet
* aos`$*1 - name of te aos service (you can type "gsv aos*" to list all AOSes with names and secription, buck sign has a special meaning in PSh so it is escaped with `. when I am working with Ax 2009, I write just like "sasv aos5*1" because there is no any other service which is matcving such a mask)
* done - is a function which is defined in [http://www.axaptapedia.com/Image:Mic...ll_profile.zip my profile] outputting just a message "done"
[System.Reflection.Assembly]::LoadWithPartialName("System.Windows.Forms")
function msgBox($x){
[System.Windows.Forms.MessageBox]::Show($x, 'Done!:PowerShell',
[Windows.Forms.MessageBoxButtons]::OK,
[Windows.Forms.MessageBoxIcon]::Information, [Windows.Forms.MessageBoxDefaultButton]::Button1,
[Windows.Forms.MessageBoxOptions]::ServiceNotification
function done(){
msgBox("done")
So there is no need to switch to "services" applet constantly pressing "Refresh"
== Something like SQL ==
PowerShell have some commands which work like sql. For example, when I looking for extendions of indezes which are related to application labels, I typed the following
ls *ru* | group extension
it means output all files, that have "ru" substring in name and group it by extension
Count Name Group
1 .ahi {C:\Program Files\Microsoft Dynamics AX\50\Application\Appl\Dynamics...
1 .alt {C:\Program Files\Microsoft Dynamics AX\50\Application\Appl\Dynamics...
1 .ahd {C:\Program Files\Microsoft Dynamics AX\50\Application\Appl\Dynamics...
1 .alc {C:\Program Files\Microsoft Dynamics AX\50\Application\Appl\Dynamics...
1 .ald {C:\Program Files\Microsoft Dynamics AX\50\Application\Appl\Dynamics...
1 .ali {C:\Program Files\Microsoft Dynamics AX\50\Application\Appl\Dynamics...
It printed groups, whith the following columns:
* count - number of elements in the group
* name - name of the group
* group - elements in the group
because I wanted only names, I typed:
ls *ru* | group extension | select name
which has in result
Name
.ahi
.alt
.ahd
.alc
.ald
.ali
== links ==
* [http://stevegilham.blogspot.com/2008...p3-is-out.html Workaround to change group policy for CTP3]
* [http://code.google.com/p/farnet/ PowerShell plugin for FarManager]
* [http://www.axaptapedia.com/Image:Mic...ll_profile.zip My profile] for PowerShell v2 CTP 2
axcoder: How to hide Content Pane in Ax 2009 Blog bot DAX Blogs 0 02.07.2008 00:07
axcoder: Book review: “Quality Assurance for Dynamics AX-Based ERP Solutions” Blog bot DAX Blogs 0 27.04.2008 18:07
axcoder: How to setup Ax 4 on a computer which does not belong to any domain Blog bot DAX Blogs 0 07.12.2007 12:00
Часовой пояс GMT +3, время: 17:17.
