Старый 06.01.2009, 17:03   #1
AndrianG is offline
AndrianG
Подскажите в чем проблема у Lookup
Хочу перекрыть метод lookup и при нажатия на стелку чтобы появилась таблица СustTable , делаю все как показано ниже и при нажатии Axapta вырубается !
  1. In the AOT, click Forms, and then locate a form that you want to add a lookup form to.
  2. Click the form, and then click Designs > Design.
  3. Add one of the following types of controls that support a lookup form:
  4. DateEdit
  • GuidEdit
  • Int64Edit
  • IntEdit
  • RealEdit
  • StringEdit
  • TimeEdit
  1. For more information about form controls, see Create Form Controls.
  2. Right-click the control, click Properties, and confirm that the LookupButton property is set to Auto.
  3. Click the control, right-click Methods, click Override Method, and then click Lookup.
    The code editor appears.
  4. Call the performDBLookup or performTypeLookup member method of one of the following classes:
    FormDateControl
    FormGuidControl
    FormInt64Control
    FormIntControl
    FormRealControl
    FormStringControl
    FormTimeControl
    In the following example, a field ID and a table ID are passed to the performDBLookup method to display the table field when a user clicks the lookup button.
    public void lookup()
    FormStringControl formStringControl;
    formStringControl = element.design().controlname("myControl2");
    formStringControl.performDBLookup(4,77);
Старый 06.01.2009, 17:19   #2
AndrianG is offline
AndrianG
Можно и так но мно кода нужно написать !
Query query = new Query();
QueryBuildDataSource queryBuildDataSource;
QueryBuildRange queryBuildRange;
// Create an instance of SysTableLookup where 'this'
// is the current form control.
SysTableLookup sysTableLookup =
SysTableLookup::newParameters(tableNum(custTable), this);
// Add fields to be shown in the lookup form.
sysTableLookup.addLookupField(fieldNum(CustTable, AccountNum));
sysTableLookup.addLookupField(fieldNum(CustTable, Name));
// Limit and arrange the data selection.
queryBuildDataSource = query.addDataSource(tableNum(CustTable));
queryBuildRange = queryBuildDataSource.addRange(
queryBuildRange.value('0..Z');
sysTableLookup.parmQuery(query);
// Perform the lookup.
sysTableLookup.performFormLookup();
//Don't call super() (commented out in the code).
// super()
Старый 06.01.2009, 17:38   #3
Сообщение от AndrianG Посмотреть сообщение
Ну... просто прочитайте хелп дальше.
достаточно просто унаследовать тип контрола от CustAccount.
Тогда вообще ничего писать не придется.
Если же так хочется пописать (с любым ударением в слове),
то для такого простого лукапа наверняка лучше просто юзать performTypeLookup(typeId(CustAccount)).
lookup
Проблема с единицей измерения longson DAX: Программирование 4 16.07.2007 14:35
Проблема с Lookup Form artem-t DAX: Программирование 5 17.01.2007 13:15
Как вызывается lookup-форма InventLocationIdLookup из InventJournalTransfer? brm DAX: Программирование 9 09.02.2005 15:37
Проблемы с Lookup monk DAX: Программирование 1 17.02.2004 14:08
Проблема с Lookup Berty Wooster DAX: Программирование 2 10.02.2004 14:58
Часовой пояс GMT +3, время: 21:34.
