Старый 17.10.2008, 12:13   #1
sergeyjb is offline
sergeyjb
Аватар для sergeyjb
68 / 12 (1) ++
Обращение к CrmService
Стандартный код выдает ошибку
using System;
using System.Data;
using System.Configuration;
using System.Collections;
using System.IO;
using System.Web;
using System.Web.Security;
using System.Web.UI;
using System.Web.UI.WebControls;
using System.Web.UI.WebControls.WebParts;
using System.Web.UI.HtmlControls;
using System.Xml;
using CrmSdk;
using CrmSdk.Discovery;
public partial class UpdateActivity : System.Web.UI.Page
protected void Page_Load(object sender, EventArgs e)
Response.Clear();
Response.ContentType = "text/xml";
CrmAuthenticationToken token = new CrmAuthenticationToken();
token.AuthenticationType = 0;
token.OrganizationName = "Samarasoft";
CrmService crmService = new CrmService();
crmService.CrmAuthenticationTokenValue = token;
crmService.Credentials = System.Net.CredentialCache.DefaultCredentials;
AppSettingsReader appSettings = new AppSettingsReader();
crmService.Url = appSettings.GetValue("CrmSdk.CrmService", Type.GetType("System.String")).ToString();
task my_task = new task();
my_task.subject = "my_task_1";
Guid t_guid = new Guid("A64664F4-E699-DD11-B4E0-00A0C5B316E9");
Owner t_owner = new Owner();
t_owner.Value = t_guid;
t_owner.type = EntityName.systemuser.ToString();
my_task.ownerid = t_owner;
Guid accountId = crmService.Create(my_task);
Ошибка идет на шаге Guid accountId = crmService.Create(my_task); такая:
Exception information:
Exception type: SoapException
Exception message: System.Web.Services.Protocols.SoapException: Сервер не распознал значение заголовка HTTP SOAPAction: http://schemas.microsoft.com/crm/200...ervices/Create.
в System.Web.Services.Protocols.Soap11ServerProtocolHelper.RouteRequest()
в System.Web.Services.Protocols.SoapServerProtocol.Initialize()
в System.Web.Services.Protocols.ServerProtocol.SetContext(Type type, HttpContext context, HttpRequest request, HttpResponse response)
в System.Web.Services.Protocols.ServerProtocolFactory.Create(Type type, HttpContext context, HttpRequest request, HttpResponse response, Boolean& abortProcessing)
Request information:
Request URL: http://crm:1001/UpdateActivity.aspx?...Mode=Completed
Request path: /UpdateActivity.aspx
User host address: 192.168.100.62
User:
Is authenticated: False
Authentication Type:
Thread account name: NT AUTHORITY\NETWORK SERVICE
Что то я уже всю голову сломал в чем дело - стандартная конструкция не работает
Подскажите в чем может быть дело...
Сергей Осипов, MCTS:SQL Server 2005, ООО "Программные технологии", Самара
Старый 17.10.2008, 12:46   #2
sergeyjb is offline
sergeyjb
Аватар для sergeyjb
68 / 12 (1) ++
В других конструкциях он такое же выдает, например
activitypointer act = (activitypointer)crmService.Retrieve(EntityName.activitypointer.ToString(), idGuid, new AllColumns());
Какой то неправильный у меня сервис получился, а в чем причина не пойму...
Старый 17.10.2008, 14:45   #3
Артем Enot Грунин is offline
Артем Enot Грунин
Аватар для Артем Enot Грунин
3,912 / 623 (28) +++++++
Записей в блоге: 151
Это вы скопировали из дебаггера? Приведите пожалуйста стек трасировки из лога ошибок сервера.
Старый 17.10.2008, 16:46   #4
Гуревич Денис is offline
Гуревич Денис
228 / 67 (3) ++++
Вообще-то, поскольку у Вас aspx-страничка, то я бы для начала вот это прочитал:
http://msdn.microsoft.com/en-us/library/cc151050.aspx
За это сообщение автора поблагодарили: sergeyjb (1).
Старый 19.10.2008, 12:16   #5
maclai is offline
maclai
Сергеи, посмотрите http://localhost:<порт>/sdk/list.aspx. Похоже,
при создании task activityid является обязателним атрибутом.
Старый 20.10.2008, 08:14   #6
sergeyjb is offline
sergeyjb
Аватар для sergeyjb
68 / 12 (1) ++
maclai:
Интересная страница, не знал о ее существовании.
Действительно поле activityid отмечено как Required For Grid.
Удивило то, что ownerid не помечено как обязательное, хотя на форме поле "ответственный" стоит с красной звездочкой.
Гуревич Денис:
Спасибо за ссылку, сейчас попробую как там пишут. Есть подозрение судя по ошибкам что с самим сервисом не порядок а не с набором отправляемых полей. Я ожидал бы другой ошибки если обязательное поле отсутствовало.
Хотя попробую все варианты.
Артем, это часть целого сообщения в системном журнале: "Журналы Windows - Приложение".
Если есть отдельный журнал ошибок CRM сервера то подскажите где его посмотреть.
А из системного полный текст ошибки (точнее предупреждения):
Код:
Event code: 3005
Event message: Возникло необработанное исключение.
Event time: 20.10.2008 8:47:52
Event time (UTC): 20.10.2008 3:47:52
Event ID: 907e722b17074104b8b6d5540dbae94c
Event sequence: 6
Event occurrence: 1
Event detail code: 0
Application information:
Application domain: /LM/W3SVC/3/ROOT-1-128689480638620121
Trust level: Full
Application Virtual Path: /
Application Path: C:\inetpub\Infrastructure\
Machine name: SRV-CRM-01
Process information:
Process ID: 1828
Process name: w3wp.exe
Account name: NT AUTHORITY\NETWORK SERVICE
User:
Thread information:
Thread ID: 5
Is impersonating: False
Stack trace: в System.Web.Services.Protocols.SoapHttpClientProtocol.ReadResponse(SoapClientMessage message, WebResponse response, Stream responseStream, Boolean asyncCall)
в System.Web.Services.Protocols.SoapHttpClientProtocol.Invoke(String methodName, Object[] parameters)
в CrmSdk.CrmService.Create(BusinessEntity entity) в c:\Windows\Microsoft.NET\Framework64\v2.0.50727\Temporary ASP.NET Files\root\5c7d8db1\29570109\App_WebReferences.wh6ss6eb.0.cs:строка 204
в UpdateActivity.Page_Load(Object sender, EventArgs e) в c:\inetpub\Infrastructure\UpdateActivity.aspx.cs:строка 64
в System.Web.Util.CalliHelper.EventArgFunctionCaller(IntPtr fp, Object o, Object t, EventArgs e)
в System.Web.Util.CalliEventHandlerDelegateProxy.Callback(Object sender, EventArgs e)
в System.Web.UI.Control.OnLoad(EventArgs e)
в System.Web.UI.Control.LoadRecursive()
в System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
Custom event details:
Старый 20.10.2008, 08:32   #7
sergeyjb is offline
sergeyjb
Аватар для sergeyjb
68 / 12 (1) ++
Добавление конструкции для activityid проблему не решило, но на будущее лишним явно не будет.
Key t_key = new Key();
t_key.Value = new Guid();
my_task.activityid = t_key;
Сейчас буду с Impersonate разбираться.
Не зря в логе:
Не думал сначала что обращение к сервису с ASPX страницы отличается от стандартного примера в SDK. Предполагал что они в расчете на WEB доступ пример писали.
Старый 28.10.2008, 14:57   #8
Артем Enot Грунин
Сергей, возможно более подробную информацию об ошибке вы получите из логов сервера. Вот статья о том как можно их включить: http://support.microsoft.com/kb/907490/en-us. В своё время я так и отлаживался, так как в дебагер валится лишь общая ошибка веб сервиса.
Старый 29.10.2008, 07:23   #9
sergeyjb is offline
sergeyjb
Аватар для sergeyjb
68 / 12 (1) ++
Спасибо Артем, а то с отладкой мне трудновато
Старый 29.10.2008, 13:58   #10
Артем Enot Грунин
Помогло проблему устранить?
Старый 30.10.2008, 14:30   #11
sergeyjb is offline
sergeyjb
Аватар для sergeyjb
68 / 12 (1) ++
Я сейчас переключился на интеграцию с шарпоинтом экстренно, через пару дней к этим кнопкам вернусь - тогда и опробую.
Тут вопрос возник с плагином на удаление акаунта.
На первой же строке валиться, причем такой же плагин на крейт акаунта работает.
Выдает ошибку:
Не удалось привести тип "Microsoft.Crm.Sdk.Moniker" объекта к типу "Microsoft.Crm.Sdk.DynamicEntity".
Что эта ошибка вообще означает? И почему при крейте проблем с приведением у него нет?
Выдает такое как на пре- так и пост-срабатываение.
Есть какая-то особенность обращения к объекту, вызвавшему плагин на удаление?
Код:
using System;
using System.Collections.Generic;
using System.Text;
using System.IO;
using Microsoft.Crm.Sdk;
using Microsoft.Crm.SdkTypeProxy;
using ShPAccountDeletePlugin.st2;
namespace ShPAccountDeletePlugin
    public class UpdateAccountOnDelete : IPlugin
        public void Execute(IPluginExecutionContext context)
            DynamicEntity entity = (DynamicEntity)context.InputParameters.Properties[ParameterName.Target];
Старый 30.10.2008, 14:50   #12
Артем Enot Грунин
Видимо это и означает - типовой class cast. Properties[ParameterName.Target] имеет тип Moniker а не DynamicEntity. Почему - вопрос хороший.
Старый 30.10.2008, 15:01   #13
Артем Enot Грунин
Из опыта работы с CRM 3.0... Плагины (тогда еще колауты) событий создания и изменения тогда тоже оперировали DynamicEntity, а вот события смены состояния и удаления, по какой-то идиотской логике получали лишь id и имя сущности. Теперь и то и другое содержится в классе Moniker. Видимо вам придется вычитывать объект самостоятельно. Печально, но Microsoft последовательна в своем идиотизме.
Старый 31.10.2008, 15:27   #14
sergeyjb is offline
sergeyjb
Аватар для sergeyjb
68 / 12 (1) ++
Повешусь скоро
Мало того что все в кучу в этой CRM - и java script, и C#, и ASP, и dll, и Web-services, так еще и через одно место
Спасибо за разьяснение, буду знать где рыть... А то я с колаутами в 3.0 не работал, не знал что такой нюанс есть.
Последний раз редактировалось sergeyjb; 31.10.2008 в 15:30.
Старый 31.10.2008, 15:29   #15
Сабитов Андрей is offline
Сабитов Андрей
MCTS
Аватар для Сабитов Андрей
851 / 122 (6) +++++
Добро пожаловать в наш МИР !!!
Старый 05.11.2008, 13:22   #16
sergeyjb is offline
sergeyjb
Аватар для sergeyjb
68 / 12 (1) ++
Артем, имея объект типа Moniker в плагине на удаление я оптимальным путем вытаскиваю значение пользовательского атрибута в следующем коде? Ничего по незнанию лишнего не написал тут? Первый раз такую вещь програмлю. Чтоб потом по одним и тем же граблям не ходить думая что это оптимальный код.
Код:
Moniker moniker = (Moniker)context.InputParameters[ParameterName.Target];
Guid accountId_read = moniker.Id;
ICrmService service_read = context.CreateCrmService(true);
TargetRetrieveDynamic target = new TargetRetrieveDynamic();
target.EntityId = accountId_read;
target.EntityName = EntityName.account.ToString();
Microsoft.Crm.Sdk.Query.ColumnSet cols = new Microsoft.Crm.Sdk.Query.ColumnSet(new string[] { "name", "new_sharepointdocumentlibrarytitle" });
RetrieveRequest retrieve = new RetrieveRequest();
retrieve.Target = target;
retrieve.ColumnSet = cols;
retrieve.ReturnDynamicEntities = true;
RetrieveResponse response = (RetrieveResponse)service_read.Execute(retrieve);
DynamicEntity retrievedEntity = (DynamicEntity)response.BusinessEntity;
string listName = retrievedEntity["new_sharepointdocumentlibrarytitle"].ToString();
Старый 05.11.2008, 14:22   #17
Артем Enot Грунин
Боюсь, Сергей, как коддер я уже выпал из обоймы, но пару советов все же дам.
Во первых, специализированные методы выполняются быстрее, чем Excecute. Обычно об этом можно не думать, но в случае плагина стоит заняться оптимизацией. Иными словами я использовал бы метод Retrieve вместо Excecute.
Во вторых, данная функциональность, думаю, потребуется вам не один раз, так что имеет смысл вынести этот код в родительский класс. Иными словами сделать некий ANormalParameterPlugin : IPlugin, который бы корректно поддерживал интерфейс, но умел полиморфно вычитывать DE на основании Moniker.
Быстродействие CrmService Bakai Madybaev Dynamics CRM: Разработка 16 21.03.2009 22:57
Обращение к полю сущности MFCшный Wizard Dynamics CRM: Разработка 28 12.02.2009 14:35
аутентификация crmService if_maks Dynamics CRM: Разработка 2 25.12.2008 11:52
Обращение! - Ответственный контакт? AlekseyS Dynamics CRM: Разработка 1 09.09.2008 13:04
Обращение: невозможно добавить Контракт Lazarus Dynamics CRM: Функционал 2 01.07.2008 13:02
Часовой пояс GMT +3, время: 21:40.
