Старый 04.04.2008, 10:05   #1
palleagermark: Spell checking from AX
Источник: http://palleagermark.blogspot.com/20...g-from-ax.html
The AX class SysSpellChecker is a wrapper for the spellchecker of Word. Using this class you can offer spellchecking from AX.
Here is some sample code, checking text from a form string control:
    SysSpellChecker spellChecker    = SysSpellChecker::newCurrentLanguage();
    TextBuffer      textBuffer      = new TextBuffer();
    int             wordStart;
    int             startSeparator;
    int             endSeparator;
    str             wordToCheck;
    List            spellingSuggestions;
    ListEnumerator  listEnumerator;
    super();
    startLengthyOperation();
    setPrefix("Spell check");
    textBuffer.setText(stringEdit.text());
    startSeparator = 1;
    while (startSeparator)
        wordStart      = textBuffer.find('[^ \n\t\\!\\'\\\#\%\&\/\(\)\=\?\,\.\:\;\*\}\{\|]', startSeparator) ? textBuffer.matchPos():0;
        if (!wordStart)
            break;
        endSeparator   = textBuffer.find('[ \n\t\\!\\'\\\#\¤\%\&\/\(\)\=\?\,\.\:\;\*\}\{\|]', wordStart)? textBuffer.matchPos():0;
        wordToCheck    = textBuffer.subStr(wordStart, (endseparator ? endseparator : textBuffer.size()+1) - wordStart);
        if (spellChecker.checkSpelling(wordToCheck) == false)
            warning (strfmt("@SYS84009", wordToCheck));
            spellingSuggestions = spellChecker.getSpellingSuggestions(wordToCheck);
            listEnumerator = spellingSuggestions.getEnumerator();
            while (listEnumerator.moveNext())
                info (strFmt("Suggestion: %1", listEnumerator.current()));
        startSeparator = endSeparator;
    spellChecker.finalize();
    info ("Spell check done");
    endLengthyOperation();
Unfortunately there is a bug in the checkSpelling method of the COM object from Word, so it will always use your default language of your Office setup as the language to check your text again. So you can't spellcheck for other languages than you default language of Office. You can change the default language from the Office Tools.
palleagermark: Creating an image file based on plain text from AX Blog bot DAX Blogs 0 03.03.2009 03:08
palleagermark: Channel 9 video: Dynamics AX Version Control interview from Convergence in Copenhagen 2008 Blog bot DAX Blogs 0 30.01.2009 16:05
Malaysia: Spell checking from AX Blog bot DAX Blogs 0 15.05.2008 22:05
Часовой пояс GMT +3, время: 05:13.
