Старый 31.03.2008, 16:05   #1
dax-lessons: Stopping and starting services using x++
Источник: http://DAX-Lessons.spaces.live.com/B...FCD1!141.entry
This short code snippet shows how you can access the status of any windows services using X++. Also, it is easy to start and stop windows services programmatically.
Before you start running the code, you need to add reference System.ServiceProcess from the AOT references node.
Note : Get_status() method is used to get the status of the service. Code can be modified according to the status of the service.
[FONT='Calibri]static void start_stop_Service(Args _args)
    System.ServiceProcess.ServiceController controller = new System.ServiceProcess.ServiceController();
    controller.set_MachineName('.');
    controller.set_ServiceName("IISADMIN");
    controller.Stop();
    sleep(500);
    controller.Start();
[/FONT]
Часовой пояс GMT +3, время: 17:50.
