Старый 03.07.2007, 00:31   #1
Issues concerning X++: CLR interop: Passing Int16 values to managed code.
Источник: http://blogs.msdn.com/x/archive/2007...aged-code.aspx
As you all know, Dynamics AX supports 32 bit integers in its int datatype. However, sometimes you need to transfer an int16 value to a managed method. Currently the easiest way to acheive this is by doing:
static void Job2(Args _args)
{ System.Int16 short;
int num = 2356;
short = System.Convert::ToInt16(num);
print short;
pause;
Issues concerning X++: Missing values: getting the System.Missing.Value value Blog bot DAX Blogs 0 16.01.2008 02:49
Arijit Basu: Microsoft Dynamics AX CLR Interop Blog bot DAX Blogs 0 07.10.2007 01:03
Issues concerning X++: Managed enumeration types and X++ Blog bot DAX Blogs 0 03.07.2007 00:31
Issues concerning X++: Using arrays with CLR interop Blog bot DAX Blogs 0 25.06.2007 12:40
Часовой пояс GMT +3, время: 11:07.
