Старый 13.05.2007, 17:12   #1
casperkamal: Using ADO to read from Excel in Microsoft Dynamics Ax
Источник: http://casperkamal.spaces.live.com/B...CD63!288.entry
        Sometime back i had a posting referring to Gloomies blog (click to see the old posting) on using ADO in Ax. Gloomie had  used COM based ADO control. Ax also has  predefined ADO Com classes which  you can use....
  Here's a small Job that will help you in working with the Inbuild ADO classes
static void JobADOtoAccessExcelInAxapta(Args _args)
    CCADOConnection  adoexcel     = new CCADOConnection();
    CCAdoxCatalog    adoCatalog   = new CCAdoxCatalog();
    COM              adoxCatalog  = new COM('ADOX.Catalog');
    CCADORecordSet   adoRecordSet = new CCADORecordSet();
    CCADOFields      adoFields;
    CCADOField       adoField;
    int               i;
    adoexcel.connectionString("Provider=Microsoft.Jet.OLEDB.4.0;Data Source=
    C:\TestAdo.xls  ;Extended Properties='Excel 8.0;HDR=Yes;IMEX=1'");
    adoexcel.open();
    adoxCatalog.activeConnection(adoexcel.connection());
    adoCatalog.adoxCatalog(adoxCatalog);
    print adoCatalog.tableName(1);
    pause;
    adoRecordSet.open(@"SELECT * FROM [SHEET1$]", adoexcel);
    adoFields = adoRecordSet.fields();
    for (i = 0; i < adoFields.count(); i++)
        adoField = adoFields.itemIdx(i);
        print adoField.name();
        pause;
    while (! adoRecordSet.EOF())
            print adoField.value();
            pause;
        adoRecordSet.moveNext();
Here is a snap shot of the excel that i used for the job....
.................. Keep watching while I post more on this ...
Старый 14.05.2007, 11:53   #2
konopello is offline
konopello
SAP
SAP
628 / 76 (4) ++++
Вот меня всегда интересовал вопрос как правельно наложить фильтр на запрос
например по полю name=konopello или city=Minsk
Старый 14.05.2007, 11:59   #3
kashperuk is offline
kashperuk
Аватар для kashperuk
4,361 / 2084 (78) +++++++++
Вырезка кода из Jobs (тестовых) проекта Gustav - ImportFromOfficeDB
    // cool real SQL-query to Excel sheet !!! have you ever dreamt about it ?!
    doc.setRecordSource(
        'SELECT * FROM [EmplTable$] WHERE Left([Name],1) IN             ' +
        ' SELECT TOP 1 FirstLetter FROM                                 ' +
        '   SELECT TOP 3 FirstLetter, Count(*) AS CountOfFirstLetter    ' +
        '   FROM                                                        ' +
        '     SELECT Left([Name],1) AS FirstLetter, [EmplTable$].*      ' +
        '     FROM [EmplTable$]                                         ' +
        '   GROUP BY FirstLetter                                        ' +
        '   ORDER BY Count(*) DESC                                      ' +
        ' ORDER BY CountOfFirstLetter                                   ' +
    // this query returns subset of records from worksheet EmplTable,
    //   in which every name of employee starts with character,
    //      which is on 3rd position in rank of more popular first characters in Name field (Oh Mein Got! :-))
Dynamics AX: Microsoft's strategy and vision for Dynamics AX and SOA Blog bot DAX Blogs 0 05.03.2009 18:05
Dynamics AX: Interview with Microsoft Dynamics Executives Blog bot DAX Blogs 0 31.05.2008 00:10
Сергей Герасимов: Что нового в Microsoft Dynamics AX 4.0 Blog bot DAX Blogs 0 16.01.2007 11:00
Часовой пояс GMT +3, время: 19:18.
