Старый 26.01.2007, 00:52   #1
Dynamics AX: Dynamics AX 4.0 Installation & Configuration [I passed!]
Источник: http://dynamics-ax.blogspot.com/2007...tallation.html
Well I would like to thank my Creator, [YHWH] and Jesus / Yeshua Christ for giving me the ability to pass the Dynamics AX 4.0 Installations & Configuration exam this morning.
This is the fist DAX 4.0 exam I have taken and I would rank it as a 6.5 out of 10 for being hard. The reason it is not higher, is because the exam pulls from the course ware found on Partner Source. Of course I would recommend actually have worked with DAX 4.0, and installed it a few times, but the Course ware walks you through all of that.
So that means that I can now adorn the title:
Microsoft Certified Business Management Solutions Specialist, MCBMSS
Dynamics AX 4.0 Installation & Configuration (v 4.0)
Man that is a mouth full... either way, a little celebration is in order, then off to focus on more work, and more certs!
Find a job at: www.DynamicsAXJobs.com
Dynamics AX: Dynamics AX 2009 & SQL Server 2008 Blog bot DAX Blogs 0 10.06.2008 21:08
Inside Dynamics AX 4.0: Licensing and Configuration Blog bot DAX Blogs 0 31.10.2007 11:40
Inside Dynamics AX 4.0: Usage Scenarios Blog bot DAX Blogs 0 04.10.2007 05:15
Часовой пояс GMT +3, время: 21:17.
