Вернуться   AXForum > Microsoft Dynamics AX > DAX: За рубежом > DAX in English
Старый 23.08.2006, 03:23   #1
tangolp is offline
tangolp
Lookup Custtable
I need to change the customer table lookupwindow you get when creating a new order. I would like to filter the dataset and don't know where to put the codet. Can anyone provide help on how to achieve this? Sample of code would be helpfull. Thank you much!!
Старый 23.08.2006, 07:57   #2
Antant is offline
Antant
change properties in extended data type 'CustAccount'
И почему никто меня не любит?
Да, я надоедливый
Старый 23.08.2006, 08:15   #3
TasmanianDevil is offline
TasmanianDevil
Мрачный тип
Аватар для TasmanianDevil
887 / 389 (14) ++++++
Filtering of lookup dataset may be done by two ways:
1)Globally - extend table links with used EDT by some BaseEnum, which will filter lookup dataset. It is like the links in Dimension table and her EDT
2)Locally - overload lookup method in your control (you must initialize system class for lookup, select the set of lookup fields and you may put some filter on your dataset in overloaded lookup method )
gatesasbait: How to define a custom lookup form for an extended datatype Blog bot DAX Blogs 0 09.07.2008 22:05
Набор однотипных lookup() методов на форме johny77 DAX: Программирование 1 10.04.2007 13:12
Нагло глючит lookup Sada DAX: Программирование 1 08.06.2006 10:32
Часовой пояс GMT +3, время: 23:02.
