Старый 08.01.2020, 19:11   #1
palleagermark: Label translations not showing in the label search dialog?
Источник: https://www.agermark.com/2020/01/lab...-in-label.html
Microsoft is now adding translated label files to the deployed developer boxes, which is supposed to make is possible to search for labels in other languages than en-us. I'm not sure if this is done for all models though.
If the search doesn't work, the likely cause is that Microsoft didn't add the related XML file for the language under \AOSService\PackagesLocalDirectory\Package\Model\AxLabelFile.
You can add these manually Here is an example for the Danish SYS label file:
Now search is able to find the Danish labels:
dynamicsaxse: November 2018 Release – Dynamics AX2012 R3 update Blog bot DAX Blogs 0 15.11.2018 09:11
palleagermark: Find standard label translations Blog bot DAX Blogs 0 13.12.2017 19:11
Быстродействие метда TaxParameters::find Ace of Database DAX: Программирование 7 01.06.2017 11:46
Gareth Tucker: Global Search Add-on Alternatives for Microsoft CRM 2011 Blog bot Dynamics CRM: Blogs 0 24.07.2012 14:11
Часовой пояс GMT +3, время: 12:12.
