Старый 09.11.2018, 05:04   #1
stoneridgesoftware: How do You Tell Which Application KBs You’ve Installed on your Dynamics 365 for Finance and Operations DEV Server?
Источник: https://stoneridgesoftware.com/how-d...ns-dev-server/
Question:
How do you tell which application KBs you’ve installed on your Dynamics 365 for Finance and Operations DEV server?
Answer:
On your D365FO DEV server, go to the folder :\AosService\PackagesLocalDirectory\ApplicationSuite\Foundation\AxUpdate.  In this folder, you will see the XML files pertaining to the KBS installed.  The KB number is in the XML file in the KBNumbers tag.
Here’s an example of what you would see on a DEV server ( Build 7.2):
NOTE: The above example is from 7.2 release and may no longer apply to newer versions.
Look for these if you are on a release 8.0 environment.
  1. C:\DynamicsAX\InstallationRecords\HotfixInstallationRecords.  Look for a file with just the KB number
So, the file 4340864 is the KB number.
  1. K:\AosService\PackagesLocalDirectory\ApplicationSuite\bin\ApplicationSuite_AxUpdate.md file (open with notepad).
powerobjects: How to Integrate Power BI with Dynamics 365 for Finance and Operations Blog bot Dynamics CRM: Blogs 0 26.06.2018 01:23
stoneridgesoftware: Dynamics 365 for Operations: How to Create a New Model Blog bot DAX Blogs 0 11.02.2017 01:11
jaestevan: Microsoft Dynamics 365 for Operations Blog bot DAX Blogs 0 02.11.2016 01:11
NAV Team: How to: Set up your Microsoft Dynamics NAV installation for Single Sign-on with Office 365 using Windows PowerShell Blog bot Dynamics CRM: Blogs 0 19.12.2013 15:10
Часовой пояс GMT +3, время: 00:04.
