Старый 23.06.2018, 01:15   #1
powerobjects: How to Find the Object Type Code for Any Entity
Источник: https://www.powerobjects.com/2018/06...e-code-entity/
Each entity in the system will have an Object type code. For simplicity of understanding, think of it as a numbering system for all the entities, regardless if they are out of the box or custom. As a CRM Expert, you might encounter a situation where you will need to identify the Object Type code for an entity.
To identify the Entity name using the Object Type Code, follow these steps:
1. Enter your CRM instance.
2. Open any entity under any model, such as Accounts, Contacts, Cases, etc.
3. Open a New Record within the Entity
4. Once a new record is opened, pop out the record by selecting the icon on the top right side of the page.
5. Once enlarged, the Object Type Code is placed after the “etc.” equal sign within the URL.
Identifying the Entity of an Object Type Code
Sometimes you may receive an error message that states the Object Type Code but not the entity name or a Custom Entity Object Type Code that is not available online.
To identify the Entity name of an Object Type Code, follow these steps:
1. Follow the same steps in “how to Identify the Object Type code of an Entity” as shown above.
2. Once the record is enlarged, you can find the Object Type Code is placed after the etc. equals sign within the URL.
3. After the etc. equals sign, delete ONLY the number shown, replace it with desired number, and select Enter.
4. Now it will open a new record with the Entity Object Type Code you entered.
There you have it! For more Dynamics 365 tips and tricks, be sure to subscribe to our blog!
Happy Dynamics 365’ing!
powerobjects: How to Export a Theme from One Dynamics 365 Org to Another Blog bot Dynamics CRM: Blogs 0 16.12.2017 00:13
saurav-nav: NAV 2018 - Lots of New Objects! Blog bot NAV: Blogs 0 04.12.2017 10:11
NAV Team: How to: Enable Import/Export of Bank or Payroll Files Using the Data Exchange Framework Blog bot Dynamics CRM: Blogs 0 18.10.2013 02:33
Microsoft Dynamics CRM Team Blog: How to enable an entity to use Activity Feeds solution Blog bot Dynamics CRM: Blogs 0 10.11.2011 04:19
Nav developer: NAV 2009 - How to generate charts / KPIs Blog bot Dynamics CRM: Blogs 0 20.08.2008 11:55
Часовой пояс GMT +3, время: 07:22.
