Старый 01.11.2016, 04:13   #1
organicax: View details
Источник: https://organicax.com/2016/10/31/view-details/
When navigating around AX7 or Dynamics 365 for Operations there is a handy function called view details. If you have been working with AX for a while then you will know the right click and view details, or go to main table if you have been around AX longer. This will give you the ability to drill into the underlying setup table if there is one and you have permission to it.
So it is still there but you will have to look for the little drop down arrow and be a little bit more accurate on your right click to locate it.
Here is a quick overview.
D365O Update3 (7.0.4307.16141)
Cheers
Lachlan
Filed under: User tips
organicax: Using item tracing to view where a product was purchased and sold Blog bot DAX Blogs 0 25.03.2016 05:29
organicax: Change view between grid and details view Blog bot DAX Blogs 0 14.03.2016 02:40
emeadaxsupport: The 'view details' feature will not work on an EDT field when the field has a relation defined in the 'table references' subnode. Blog bot DAX Blogs 0 26.01.2013 02:14
dynamicsaxbi: Better together: Microsoft Dynamics AX 2012 R2 and SQL Server Power View Blog bot DAX Blogs 0 12.12.2012 13:11
palleagermark: "View details" bug in collection letter and interest note forms Blog bot DAX Blogs 0 01.08.2012 16:11
Часовой пояс GMT +3, время: 06:52.
