Старый 29.09.2016, 04:27   #1
organicax: Gantt charts for reviewing resource work
Источник: https://organicax.com/2016/09/28/gan...resource-work/
AX has had a basic Gantt chart capability for many versions. It’s been slightly tweaked through the AX2012 releases but the functionality is somewhat the same. There are more advanced Gantt solutions available with some of the ISV solutions that add a lot of “re-organization” capability if you want to use the view of the Gantt change and re-schedule. There are few places you can access the Gantt chart if you are looking at using it for production control. The out of the box capability is good enough to get that time line view which Gantt charts are good for to see what is going on with a resource.
Here is a quick overview.
AX2012 R3 CU11
Cheers
Lachlan
Filed under: Production control, Supply chain planning
emeadaxsupport: Checklist of setup and configuration items for getting Input Location from Resource assigned with Put work in Raw material picking with Warehouse Management processing in AX 2012 Blog bot DAX Blogs 0 12.08.2015 20:17
DynamicsAxSCM: WHS Work List Blog bot DAX Blogs 0 19.06.2015 15:11
axmfg: Warehouse work for raw material picking split per route operation Blog bot DAX Blogs 0 22.09.2014 18:11
axmfg: Replacing work order types for production output in CU8 Blog bot DAX Blogs 0 12.09.2014 18:12
Часовой пояс GMT +3, время: 09:53.
