Старый 19.07.2016, 14:11   #1
emeadaxsupport: How to setup Polish Standard Audit File in AX2009
Источник: https://blogs.msdn.microsoft.com/axs...ile-in-ax2009/
This article is published on behalf of Svetlana Kosheleva. The attached document will describe how to configure the Polish Standard Audit file regulatory update in AX 2009 released with KB 3165114 Summary From 1 July 2016, taxpayers in Poland will be obliged to transmit data in a unified format, the so called Standard Audit File (SAF) at... Read more
emeadaxsupport: DIXF - Importing Data - How to establish which rows you need to look at when you aren't able to import every row in your input file Blog bot DAX Blogs 0 08.10.2015 15:11
emeadaxsupport: How to setup General Budget Reservation functionality that was added after AX 2012 R3 CU8 for Public Sector Blog bot DAX Blogs 0 26.05.2015 17:11
emeadaxsupport: Positive Pay Setup in AX 2012 R2 Blog bot DAX Blogs 0 24.06.2014 23:11
NAV Team: How to: Enable Import/Export of Bank or Payroll Files Using the Data Exchange Framework Blog bot Dynamics CRM: Blogs 0 18.10.2013 02:33
Часовой пояс GMT +3, время: 03:34.
