Starting from NAV 2013 R2 CU8 or NAV 2013 CU15, we are now providing extended info in the Sales Info-Pane (Sales Order Page). This is to allow user to have clear visibility around item availability when making the right decissions to minimize inventory levels and reduce carrying costs.
Sales Info-Pane is now providing the following info around availability calculation:
The above together with the "Item availability by ..." views should provide tools to make decissions around this. As an example, if we have an availability issue when entering a new sales order, I would encourage user to open "Item Availability by Event" and determine what is the point in time where availability goes negative. On that date, I would check if we have any reserved stock for a demand with later shipment date. This other sales might instead be promised through CTP and existing stock used to account for negative availability. Lastly but not least, I would like to link this blog entry with an earlier one where I stated the fact reservations should only be done when it is strictly required. Otherwise, we might disturb planning and we might increase inventory levels if reservations are not made on a meaningful business scenario. On this assumption is where user should benefit from this Sales Info-Pane. Источник: http://feedproxy.google.com/~r/Micro...info-pane.aspx
