Старый 12.10.2012, 13:33   #1
You might recall that for NAV 2013 Beta I noted down the objects statistics here. So here is a small update moving from Beta (object date May 9, 2012) to RTM (object date September 7, 2012).
In the 4 months between Beta and RTM the NAV team clearly hasn't been leaning back with respect to NAV 2013.
Objects
NAV 2013 Beta -> RTM
Changed
1960
Removed
13
Inserted
10
So quite a substantial number of objects have been updated. 1960 on a total 3,908 objects in RTM (3,911 in Beta).
Patterns
Though some individual objects show updates in the application (bug fixes?), the major part clearly show the following update patterns:
  • Replacement of FIND('-') and FIND ('+') with FINDFIRST and FINDLAST (but in some case also the other way around)
  • Removal of unused variables
  • Update of untranslated local captions (local captions did contain a copy of ENU caption
  • Extended object permissions
  • Syncing code with coding standards
    • implicit use of record variables
    • double occurrences of semicolons
    • IF...THEN constructions
    • BEGIN...END constructions
    • CASE..END constructions
In a series of next posts I will dive into some details.
Note
This is for the NL version. However, this gives a good indication for w1 as NL localization is very restricted.
Читать дальше
Часовой пояс GMT +3, время: 04:48.
