Старый 18.08.2011, 04:11   #1
crminthefield: Error message “Assembly must be registered in isolation” when registering Plugins in Microsoft Dynamics CRM 2011
Источник: http://blogs.msdn.com/b/crminthefiel...-crm-2011.aspx
Recently I had a customer run into the error message “Assembly must be registered in isolation” when trying to register a CRM 2011 plugin. We found this error was being thrown because the user was not a deployment administrator.  If the user is only a System Administrator in the organization they will be forced to register plugins in the sandbox isolation mode.  After adding the user as a deployment administrator he was able to register the plugin to database without any issues.
In the Security Restrictions section of the following MSDN article it states, “There is a security restriction that enables only privileged users to register plug-ins. For plug-ins that are not registered in isolation, the system user account under which the plug-in is being registered must exist in the Deployment Administrators group of Deployment Manager.“
Register and Deploy Plug-ins
http://msdn.microsoft.com/en-us/library/gg309620.aspx
Generic Error
Detailed Error
Unhandled Exception: System.ServiceModel.FaultException`1[[Microsoft.Xrm.Sdk.OrganizationServiceFault, Microsoft.Xrm.Sdk, Version=5.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35]]: Action failed for assembly 'SamplePlugins, Version=0.0.0.0, Culture=neutral, PublicKeyToken=829f574d80e89132': Assembly must be registered in isolation.
Detail: http://schemas.microsoft.com/xrm/2011/Contracts" xmlns:i="
  -2147220906
  http://schemas.datacontract.org/2004/07/System.Collections.Generic"
  2011-08-17T19:15:20.1988144Z
    -2147220906
    http://schemas.datacontract.org/2004/07/System.Collections.Generic" />
Server stack trace:
   at System.ServiceModel.Channels.ServiceChannel.HandleReply(ProxyOperationRuntime operation, ProxyRpc& rpc)
   at System.ServiceModel.Channels.ServiceChannel.Call(String action, Boolean oneway, ProxyOperationRuntime operation, Object[] ins, Object[] outs, TimeSpan timeout)
   at System.ServiceModel.Channels.ServiceChannelProxy.InvokeService(IMethodCallMessage methodCall, ProxyOperationRuntime operation)
   at System.ServiceModel.Channels.ServiceChannelProxy.Invoke(IMessage message)
Exception rethrown at [0]:
   at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessage(IMessage reqMsg, IMessage retMsg)
   at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type)
   at Microsoft.Xrm.Sdk.IOrganizationService.Create(Entity entity)
   at Microsoft.Xrm.Sdk.Client.OrganizationServiceProxy.CreateCore(Entity entity)
   at PluginRegistrationTool.RegistrationHelper.RegisterAssembly(CrmOrganization org, String pathToAssembly, CrmPluginAssembly assembly) in C:\Users\jemorl\SDK\CRMSDK 2011\tools\pluginregistration\RegistrationHelper.cs:line 227
   at PluginRegistrationTool.PluginRegistrationForm.btnRegister_Click(Object sender, EventArgs e) in C:\Users\jemorl\SDK\CRMSDK 2011\tools\pluginregistration\PluginRegistrationForm.cs:line 461
Microsoft Dynamics CRM Team Blog: Announcing: Microsoft Dynamics CRM 2011 Implementation Guide update 5.1.0 Blog bot Dynamics CRM: Blogs 0 19.05.2011 22:11
Microsoft Dynamics CRM Team Blog: Migrating Customizations to Microsoft Dynamics CRM 2011 Online Blog bot Dynamics CRM: Blogs 0 18.04.2011 23:11
Microsoft Dynamics CRM Team Blog: Testing your Microsoft Dynamics CRM 2011 Apps Blog bot Dynamics CRM: Blogs 0 01.12.2010 03:14
Часовой пояс GMT +3, время: 08:37.
