emeadaxsupport: DIXF – Compare Entities – SQL Server replication tool is not installed
Источник: https://blogs.msdn.microsoft.com/axs...not-installed/
============== Consider a scenario where you are running AX 2012 R3 and you want to compare entities between AX companies using DIXF, but you get an error telling you that the SQL Server replication tool is not installed. 1. The DIXF functionality On a CONTOSO Demo Data TEST environment, you can find the functionality by navigating... Read more Источник: https://blogs.msdn.microsoft.com/axs...not-installed/
