palleagermark: Check out all several languages of a label file in one process in AX 2012
Источник: http://www.agermark.com/2016/03/chec...guages-of.html
============== If you work under version control and you update labels in more than one language, you might have found it cumbersome that you for each language need to switch language in the label dialog and then check each language out individually. I have made a job that does this in one process. The job uses saved selections from the label dialog to figure out the label file to check out, and in which languages. Use at your own risk. Источник: http://www.agermark.com/2016/03/chec...guages-of.html
