Старый 03.03.2016, 04:25   #1
emeadaxsupport: How to install and configure Windows AppFabric for AX 2012 Enterprise Portal in a multi-server web farm
Источник: https://blogs.msdn.microsoft.com/axs...rver-web-farm/
  When setting up AX 2012 Enterprise Portal (EP) in a multi-server web farm, then setting up AppFabric caching is required. This is for caching session info. When installing SharePoint 2013 it is recommended to use the prerequisite installer to install AppFabric, ref https://technet.microsoft.com/librar...ffice.15).aspx section “Plan for the Distributed Cache service”. Note: If you are... Read more
emeadaxsupport: How to update AX 2012 Enterprise Portal in a multi-server web farm Blog bot DAX Blogs 0 09.11.2015 13:11
emeadaxsupport: How to install AX 2012 Enterprise Portal in a multi-server web farm Blog bot DAX Blogs 0 09.11.2015 13:11
emeadaxsupport: How to Install the Dynamics AX Enterprise Portal in a Load Balanced SharePoint farm in 4 simple steps Blog bot DAX Blogs 0 04.06.2015 19:12
dynamics-coe: Microsoft Dynamics AX 2012 Reporting Services – Integrated with SharePoint Farm Blog bot DAX Blogs 0 21.11.2014 13:11
Часовой пояс GMT +3, время: 21:08.
