Старый 08.01.2016, 00:14   #1
emeadaxsupport: Transaction detail missing from MR reports
Источник: https://blogs.msdn.microsoft.com/axs...om-mr-reports/
After you rebuild the MR data mart, previously generated reports are missing transaction detail. If you try to drill down, the detail is missing. Once the report is re-generated, the transaction detail is there again. Transaction level detail is reliant on the detail from the data mart. In older versions of MR, the transaction detail... Read more
emeadaxsupport: Intercompany time postings incomplete at transaction voucher level when project date differs from the day posted Blog bot DAX Blogs 0 19.08.2013 19:11
emeadaxsupport: Unable to connect to the Transaction Service - The case of the missing or mismatched passphrase Blog bot DAX Blogs 0 20.09.2012 02:13
emeadaxsupport: Some reports from Reporting extensions can raise error when running on SQL 2008 R2 Blog bot DAX Blogs 0 18.03.2011 20:11
Inside Dynamics AX 4.0: Transaction Semantics Blog bot DAX Blogs 0 31.10.2007 23:40
Часовой пояс GMT +3, время: 13:43.
