emeadaxsupport: Performance issue running an Autoreport
Источник: http://blogs.msdn.com/b/axsupport/ar...utoreport.aspx
============== If some of the users experience the issue while running an auto report even with minimum amount of data, that can be cause by the client configuration used by the user. Usually you can see that for some users the autoreport works very fast while for the others it takes minutes. To solve this issue you can try: If you are using the configuration from registry - try to refresh the WCF services by clicking Refresh button in Microsoft Dynamics AX Configuration Utility ![]() You can also create a new configuration or use exact the same configuration which are using the users who not have a problem. Reference: Manage a client configuration [AX 2012] - https://technet.microsoft.com/en-us/.../aa569651.aspx Источник: http://blogs.msdn.com/b/axsupport/ar...utoreport.aspx
