Старый 17.04.2015, 16:11   #1
bojensen: Reset program cache file for all clients | Thomas Widmer’s AX Blog
Источник: http://blogs.bojensen.eu/2015/04/17/...ers-ax-blog-2/
  The following job resets the GUID which in turn forces all clients to create a new program cache file (AX_*.auc). A restart of the AOS is required. static void forceNewAUC(Args _args) { #AiF SysSQMSettings sysSQMSettings; ; ttsbegin; update_recordset sysSQMSettings setting GlobalGUID = str2Guid(#EmptyGuidString); ttscommit; info("Restart the AOS Service to generate a new GlobalGUID."); }…
Read more →
emeadaxsupport: Connecting Retail Components on an External Computer to the Microsoft Dynamics AX R3 Azure Lifecycle Services Demo Virtual Machine Blog bot DAX Blogs 0 28.06.2014 00:13
bojensen: Customize cubes [AX 2012] | Dynamics AX Forum Blog Blog bot DAX Blogs 0 21.03.2014 14:11
bojensen: How to quickly set up Application Integration Framework (AIF) for testing Axd documents – Ivan (Vanya) Kashperuk blog – Microsoft Dynamics AX – Microsoft Dynamics Community Blog bot DAX Blogs 0 17.04.2013 03:25
bojensen: Performing File IO with the TextIo Class [AX 2012] Blog bot DAX Blogs 0 02.01.2013 21:11
bojensen: How to add or delete a label file in Dynamics AX 2012 (Microsoft Dynamics AX blog by Zubair) Blog bot DAX Blogs 0 17.11.2012 11:12
Часовой пояс GMT +3, время: 17:03.
