Старый 16.02.2015, 21:11   #1
DeniZone: How to redirect/drain user clients in a cluster AOS-setup
Источник: http://denizone.blogspot.com/2015/02...lients-in.html
It may become necessary to redirect users to a specific AOS instance even though the client configuration is setup to use a AOS cluster.
If the redirect is a temporary fix such as setting an AOS-server offline for maintenance instead of editing all axc-client configurations, it is possible in the user interface to tell an AOS-server to redirect user connection to other AOS-instances in the cluster quite easily:
Open AX and navigate to the System Administration module:
In the group Users, open Online users:
On the tab Server Instances confirm that are are 2 or more AOS-instances connected to the application:
Mark the AOS-instance that you want to redirect from and press the Reject new clients button, e.g.
A prompt will ask for confirmation, press OK:
Status for the AOS instance will shift to Draining, which means that connections to the AOS-instance is in the process of drained from the AOS-instance(s).
To allow connections to the AOS-instance again, navigate to the same form, highlight the redirecting AOS instance and press the “Accept new clients”.
In this way, we have redirected new connections to an AOS-cluster away from a specific AOS-instance, without altering the client configuration.
TechNet: Drain users from an AOS
emeadaxsupport: How to enable the setup for user specific font Settings in MS Dynamics AX 2012 Blog bot DAX Blogs 0 21.06.2014 19:19
emeadaxsupport: How to perform a data center change (change of the physical location) where a SQL server 2008 R 2 cluster installation and MS Dynamics AX 4.0 is involved? Blog bot DAX Blogs 0 21.06.2014 19:19
emeadaxsupport: Capturing an AX User’s SQL SPID over multiple AOS servers in AX 2009 Blog bot DAX Blogs 0 16.05.2013 19:11
emeadaxsupport: How does the Dynamics AX Setup detect existing AOS Instances? Blog bot DAX Blogs 0 06.07.2010 17:05
Часовой пояс GMT +3, время: 00:00.
