Старый 18.05.2014, 20:11   #1
goshoom: Access denied: SysOperationServiceController
Источник: http://dev.goshoom.net/en/2014/05/ac...icecontroller/
I unexpectedly got Access denied: SysOperationServiceController when trying to call a method through the SysOperation framework in Dynamics AX 2012. It was just a piece of research code and I didn’t want to bother with my own controller, therefore I created and executed a menu item with the following properties:
PropertyValueObjectTypeClassObjectSysOperationServiceControllerEnumTypeParameterSysOperationExecutionModeEnumParameterSynchronousThe error message is a bit misleading, so it took me a minute to realize that I forget to define which method to call. Setting the Parameters property to MyClass.MyMethod did the job.
Malaysia: Access denied to field Partition (Partition) in table XXXX... Blog bot DAX Blogs 0 07.02.2014 10:11
daxdilip: Troubleshooting Error Access denied to method TRANSFER of class LedgerPostingGeneralJournalController Blog bot DAX Blogs 0 06.07.2013 15:12
a33ik: CRM 4.0 - Create new Organization failed with Exception: System.UnauthorizedAccessException: Access is denied Blog bot Dynamics CRM: Blogs 2 26.08.2011 11:07
emeadaxsupport: Workflow error System.ComponentModel.Win32Exception: Access is denied Blog bot DAX Blogs 0 09.06.2010 23:05
COM: access is denied! Пагер Маяковский DAX: Программирование 3 11.07.2005 14:22
Часовой пояс GMT +3, время: 19:04.
