Have a look at these code samples and tell me where a compound statement, i.e. BEGIN-END, should be constructed to get the code work right.
Just dare without going into NAV and verify. ![]() Sample 1 1. SalesCommentLine.SETRANGE("Document Type",SalesQHeader."Document Type"); 2. SalesCommentLine.SETRANGE("No.",SalesQHeader."No."); 3. WHILE SalesCommentLine.FIND('-') DO 4. SalesCommentLine.DELETE; 5. SalesCommentLine."Document Type" := SalesOrderHeader."Document Type"; 6. SalesCommentLine."No." := SalesOrderHeader."No."; 7. SalesCommentLine.INSERT; Sample 2 1. IF AccountingPer2.FIND('>') THEN 2. FiscalYearEndDate := CALCDATE('<-1D>',AccountingPer2."Starting Date"); 3. AccountingPer3 := AccountingPer2; 4. AccountingPer2.SETRANGE("New Fiscal Year"); 5. AccountingPer2.FIND('<') 6. ELSE 7. ERROR(Text001); Sample 3 1. CASE "Action Taken" OF 2. "Action Taken"::Won: 3. IF Opp.GET("Opportunity No.") THEN 4. SalesQuoteEnable := Opp."Sales Document No." <> ''; 5. "Action Taken"::Lost: 6. CalcdCurrentValueLCYEnable := FALSE; 7. SalesQuoteEnable := FALSE; 8. END; Sample 4 1. CASE LOWERCASE("XBRL Item Type") OF 2. 'stringitemtype','string': 3. "Source Type" := "Source Type": ![]() 4. 'monetaryitemtype': 5. "Source Type" := "Source Type"::"General Ledger"; 6. 'decimalitemtype': 7. "Source Type" := "Source Type"::Constant; 8. 'sharesitemtype' : 9. "Source Type" := "Source Type"::Constant; 10. 'uriitemtype': 11. "Source Type" := "Source Type": ![]() 12. 'tupletype': 13. "Source Type" := "Source Type"::Tuple; 14. ELSE 15. "Source Type" := "Source Type"::"Not Applicable"; 16. IF "XBRL Item Type" <> '' THEN 17. Description := STRSUBSTNO(Text007,"XBRL Item Type"); 18. END; Sample 5 1. WITH ResJnlLine2 DO 2. IF "Resource No." <> '' THEN 3. IF ResJnlTemplate.Recurring THEN BEGIN 4. TESTFIELD("Recurring Method"); 5. TESTFIELD("Recurring Frequency"); 6. IF "Recurring Method" = "Recurring Method"::Variable THEN 7. TESTFIELD(Quantity); 8. END ELSE BEGIN 9. TESTFIELD("Recurring Method",0); 10. TESTFIELD("Recurring Frequency","0DF"); 11. END;For reference I have added numbers to each code line. Please use it as follows: if in case in Sample 2 the BEGIN should be added to line 2 and it's balancing END to line 4, you could suffice with writing Sample 2 - line2/line4. Читать дальше
