Старый 05.03.2013, 07:13   #1
emeadaxsupport: Unit of Measure field is not saving when creating an Item within Dynamics Ax using a Company Template
Источник: http://blogs.msdn.com/b/axsupport/ar...-template.aspx
Reason:
A blank record exists in the InventItemPrice table for the company which you are currently logged in as. A validation occurs in the InventTableModule\validateField method which checks if a record exists, since it finds a blank record the Unit of Measure value cannot be saved.
Workaround:
Remove the record from the InventItemPrice table which has a blank value for the ItemID field and the DataAreaId match the company you are currently logged in as.
How it possibly could have occurred:
The InventItemPrice table is a common table which imports occur within Dynamics Ax, a blank record may have been imported during the pricing update.
emeadaxsupport: Dynamics AX 2012 Reporting: How to add company logo into query based report Blog bot DAX Blogs 0 06.12.2012 21:11
dynamics-ax: Interview with Microsoft's Lachlan Cash on his new role, AX 2012 and more Blog bot DAX Blogs 6 22.04.2011 14:55
emeadaxsupport: Resolving some issues you may experience when creating an AX 2009 Role Center and Enterprise Portal Site using SharePoint Server/Foundation 2010 after installing Microsoft Dynamics AX 2009 SP1 hotfix 2278963 Blog bot DAX Blogs 1 24.09.2010 11:34
Часовой пояс GMT +3, время: 11:21.
