Старый 30.10.2012, 01:15   #1
ax-erp: Delete AUC File Of Users
Источник: http://microsoft-dynamics-ax-erp.blo...-of-users.html
static void ClearAucFileForUsers(Args _args)
    System.Array    files;
    int             fileCount;
    int             i;
    str             nextFile;
    str             path = "C:\\Users";
    str             Finalpath;
    str             pattern = "*.auc";
    container       listOfFiles;
    int             DirCount;
    System.Array    Directories;
    int             j;
    str             nextDir;
    container       listOfDir;
    FileIOPermission    dirPermission, filePermission;
    InteropPermission   interopPermission;
    Set                 permissionSet;
    new InteropPermission(InteropKind::ClrInterop).assert();
    listOfDir = conNull();
    listOfFiles     = connull();
    Directories = System.IO.Directory::GetDirectories(path);
    if(Directories)
        DirCount = Directories.get_Length();
        for(j=0; j < DirCount; j++)
            nextDir    = Directories.GetValue(j);
            Finalpath = nextDir + "\\AppData\\Local";
            listOfDir += Finalpath;
    j=0;
    DirCount = conLen(listOfDir);
    while( j < conLen(listOfDir))
        j++;
        Finalpath = conPeek(listOfDir,j);
        try
            files           = System.IO.Directory::GetFiles(Finalpath, pattern);
        catch
            continue;
        if (files)
            fileCount =    files.get_Length();
            for(i=0; i < fileCount; i++)
                nextFile    = files.GetValue(i);
                System.IO.File::Delete(nextFile);
                info(nextFile);
    CodeAccessPermission::revertAssert();
Последний раз редактировалось Poleax; 30.10.2012 в 11:53. Причина: оформление
auc, кеш, чистка
ax-erp: Creating SSRS-Reports in Dynamics AX 2012 – What’s no longer possible in AX-reports Blog bot DAX Blogs 0 18.07.2012 12:11
emeadaxsupport: Identical AX 2009 AUC File Created For Multiple AX Installations Blog bot DAX Blogs 0 25.01.2010 16:05
Часовой пояс GMT +3, время: 13:27.
