kamalblogs: ALM (Deployment) with Dynamics Ax 2012 R2
Источник: http://kamalblogs.wordpress.com/2012...cs-ax-2012-r2/
============== - Metadata db and the datadb can now be separate - Single user Topology for development: Microsoft recomments the Single user topology when using sourcecontrol and to manage multiparty development - Shared application topology is not recommened for the following reasons - To debug a Pcode the visual studio needs to be used. During the attach process the AOS is paused for all user - Server restarts for a single user stops the entire application - Visual Studio Projects – Apart from the Synchornize to the AOT, we must right scripts to run MSbuild for these projects. This ensures a proper VS project import Deploying to the Production - Element id’s as we all know is generated during the import of models, so it is recommended not to import models in to Production system to avoid id conflicts - Maintain a seperate staging setup where the metadatastore of the production and staging are maintained commonly. Import models to the staging and then move the metadata - Model store import is quicker, will bring the down time and speed up import. ![]() Источник: http://kamalblogs.wordpress.com/2012...cs-ax-2012-r2/
