Вернуться   AXForum > Microsoft Dynamics AX > DAX: За рубежом > DAX in English
Старый 20.09.2012, 12:28   #1
Pierre is offline
Pierre
AX 2012. Report 'Missing timesheets'. Which class/job is used to send mails?
We use report 'Project management and accounting->Reports->Hours->Missing timesheets'.
This report has filter 'Send e-mail':
This report doesn't send any mail.
Which other functionality/jobs are used to send mails ?
We want to understand the process. How the emails are sent.
Старый 21.09.2012, 09:00   #2
gl00mie is offline
gl00mie
3,684 / 5813 (201) ++++++++++
I'm not sure about AX 2012, but in previous versions emails are not sent immediately, but rather stored for asynchronous dispatch which is performed by a batch email processor. Go to Administration/Periodic/Email-Processing/Batch to setup one. Make sure that you have an AOS that is assigned to execute batch jobs of the corresponding batch group. Note that an empty batch group (if you use one) must also be assigned to a batch server.
Старый 21.09.2012, 10:49   #3
Pierre is offline
Pierre
No, in SysOutgoingEmailTable won't be created any record that should be then sent by batch email processor. There is something else.
ax2012, ssrs
ax-erp: Walkthrough: Creating a Report Bound to a Report Data Provider Class (X++ Business Logic) [AX 2012] Blog bot DAX Blogs 0 20.09.2012 11:11
ax-erp: Report Data provider [RDP] as data source type in data set – SSRS reports [Dynamics ax 2012] Blog bot DAX Blogs 0 18.07.2012 12:11
ax-erp: Creating SSRS-Reports in Dynamics AX 2012 – What’s no longer possible in AX-reports Blog bot DAX Blogs 0 18.07.2012 12:11
Часовой пояс GMT +3, время: 18:24.
