Старый 16.11.2011, 15:11   #1
Gareth Tucker: Displaying the Activity Feed Wall on a CRM Dashboard
Источник: http://gtcrm.wordpress.com/2011/11/1...crm-dashboard/
This put a smile on my face today – I was able to render the new Activity Feed Wall on a Dashboard:
Takes just 5 minutes to configure this (no coding required).  The Activity Feed Wall is rendered within an iFrame on the Dashboard all you need to know is the URL, which in my case was:
https://nov27demo.crm.dynamics.com//...rsonalWall.htm
If you are using CRM online simply localise the above URL to your Organisation name.  If running CRM on premise you will need to adjust the web site reference to match your environment.
The Dashboard looks like this in the Dashboard Designer:
With the iframe defined as below:
If you want to show the user profile component of the wall add the following suffix to your URL:
https://nov27demo.crm.dynamics.com//...serProfile%3D0
This will give you the following Dashboard:
A quick scan of the CRM sitemap revealed the web resource name of the Wall from which I was able to figure out the URL.
I think this is really cool and will become my home page of choice for demos for the next wee while.
Gareth Tucker: Activity Feeds in Microsoft CRM 2011 Blog bot Dynamics CRM: Blogs 0 16.11.2011 08:11
crminthefield: Podcast and Overview: Microsoft Dynamics CRM 2011 Update Rollup 4 Blog bot Dynamics CRM: Blogs 0 24.09.2011 01:16
Ошибка бизнес-процесса Tarasov E Dynamics CRM: Разработка 9 18.02.2010 14:02
Мелкомягкий CRM: Панель управления для MS CRM с помощью Reporting Services Blog bot Dynamics CRM: Blogs 1 24.08.2009 14:41
Часовой пояс GMT +3, время: 12:40.
