Старый 03.11.2011, 14:06   #1
u.rastegaev is offline
u.rastegaev
обнуление полей плагином
Добрый день, а вот такая простая задача, нужно плагином обнулить поля,
TargetRetrieveDynamic targetRetrieve = new TargetRetrieveDynamic();
targetRetrieve.EntityName = "contract";
targetRetrieve.EntityId = contractId;
// Create the request object.
RetrieveRequest retrieve = new RetrieveRequest();
retrieve.Target = targetRetrieve;
retrieve.ColumnSet = new AllColumns();
retrieve.ReturnDynamicEntities = true;
// Execute the request.
RetrieveResponse retrieved = (RetrieveResponse)service.Execute(retrieve);
// Extract the DynamicEntity from the request.
DynamicEntity entity = (DynamicEntity)retrieved.BusinessEntity;
entity.Properties.Remove("gar_state_contract");
entity.Properties.Remove("gar_contracts");
entity.Properties.Remove("title");
entity.Properties.Remove("activeon");
entity.Properties.Remove("gar_date_contract_expiry");
entity.Properties.Remove("gar_date_return_contract");
// Contact PreferredContactMethodCode property
PicklistProperty picklist = new PicklistProperty();
picklist.Name = "gar_state_contract";
picklist.Value = new Picklist();
picklist.Value.Value =1 ;
LookupProperty lkProp = new LookupProperty();
lkProp.Name = "gar_contracts";
lkProp.Value = new Lookup();
StringProperty strProp = new StringProperty();
strProp.Name = "title";
strProp.Value = "";
CrmDateTimeProperty dProp1 = new CrmDateTimeProperty();
dProp1.Name = "activeon";
dProp1.Value = new CrmDateTime(string.Format(System.Globalization.CultureInfo.InvariantCulture, "{0:s}", "2/24/1955"));
CrmDateTimeProperty dProp2 = new CrmDateTimeProperty();
dProp2.Name = "gar_date_contract_expiry";
dProp2.Value = new CrmDateTime(string.Format(System.Globalization.CultureInfo.InvariantCulture, "{0:s}", "2/24/1955"));
CrmDateTimeProperty dProp3 = new CrmDateTimeProperty();
dProp3.Name = "gar_date_return_contract";
dProp3.Value = new CrmDateTime(string.Format(System.Globalization.CultureInfo.InvariantCulture, "{0:s}", "2/24/1955"));
// ArrayList arrProps = new ArrayList();
// Add properties to ArrayList.
entity.Properties.Add(picklist);
entity.Properties.Add(lkProp);
entity.Properties.Add(strProp);
entity.Properties.Add(dProp1);
entity.Properties.Add(dProp2);
entity.Properties.Add(dProp3);
// Update the properties array on the DynamicEntity.
//entity.Properties =
// (Property[])arrProps.ToArray(typeof(Property));
// Create the update target.
TargetUpdateDynamic updateDynamic = new TargetUpdateDynamic();
// Set the properties of the target.
updateDynamic.Entity = entity;
// Create the update request object.
UpdateRequest update = new UpdateRequest();
// Set request properties.
update.Target = updateDynamic;
UpdateResponse updated =
(UpdateResponse)service.Execute(update);
rurik
Старый 03.11.2011, 14:07   #2
u.rastegaev
нужно вот этот участок кода или нет?
strProp.Value = "";
rurik
Старый 03.11.2011, 14:07   #3
u.rastegaev
или достаточно ?
rurik
Старый 03.11.2011, 14:16   #4
a33ik is offline
a33ik
Чайный пьяница
Аватар для a33ik
3,243 / 896 (36) +++++++
Этого мало. Если вы убираете поле и вызываете апдейт, то с полем - ничего не происходит. Для очищения посмотрите следующее - http://a33ik.blogspot.com/2009/11/cl...-dynamics.html
Для очищения поля типа стринг - просто передайте в него пустую строку.
Старый 03.11.2011, 14:21   #5
u.rastegaev
со стрингом я догадался а вот с остальными спасибо)
rurik
Старый 03.11.2011, 14:25   #6
u.rastegaev
кстати а с контрактом и строкой контракта прйдет обнуление дат начала и окончания?
там же у них привязка есть что даты строки между датами контракта
rurik
Старый 03.11.2011, 14:52   #7
a33ik is offline
a33ik
Чайный пьяница
Аватар для a33ik
Сходу не скажу, потому что никогда такого не проверял, но написать простое консольное приложение чтобы проверить, как это работает - дело 15-20 минут.
CRM 2011. Вопрос. Обновление значений полей связанных объектов Gennadi Dynamics CRM: Разработка 6 05.09.2011 15:25
Преобразование необязатаельных полей в обязательные(полнота полей) Alexey-IT Dynamics CRM: Функционал 4 22.07.2010 21:45
Ограничение прав на редактирование некоторых полей Tarasov E Dynamics CRM: Разработка 4 09.04.2010 13:20
Изменение полей типа State или Status Артем Enot Грунин Dynamics CRM: Разработка 3 10.06.2008 06:30
Видимость новых полей sam Dynamics CRM: Функционал 10 15.05.2006 17:57
Часовой пояс GMT +3, время: 07:52.
