Старый 13.10.2011, 18:11   #1
workflowax: DLLs used in Batch processes
Источник: http://workflowax.wordpress.com/2011...tch-processes/
I know this doesn’t have a lot to do with workflow in specific, but I struggled through this issue for a while without finding any other results on the net, so I’m posting it just in case somebody else struggles with the same issue.
We are running a batch job that makes use of a 3rd party DLL file. The batch process runs quite ok if we run it manually from the client, however as soon as we try and run it in batch mode it fails with a “CLR Error: cannot create object”.
The reason for this is that the batch server cannot find the DLL file to use. All the recommendations that I found to solve this error involved placing the DLL in the Global Assembly Cache (GAC) on the batch server. I understand that this would be the best way to overcome the error and should normally be the approach. However the DLL we have is not Strongly Named, so we received constant errors when trying to add it to the GAC. Unfortunately the vendor is not shipping a strongly named version of the DLL so a different approach has to be followed.
Where for client side execution of the DLL you need to place the file in C:\Program Files (x86)\Microsoft Dynamics AX\50\Client\Bin if you would like the server to access it, simply place it in C:\Program Files\Microsoft Dynamics AX\50\Server\[AOS name]\Bin on the batch server.
And like magic the batch job works. (Ok i had to restart the batch server AOS as well)
I hope this assists somebody in the near future.
axinthefield: Optimizing AX Batch Performance - Batch Group Configuration Blog bot DAX Blogs 0 01.04.2011 13:11
emeadaxsupport: How batch processing works under the hood AX2009 Blog bot DAX Blogs 0 22.02.2011 12:11
axaptapedia: Batch processing Blog bot DAX Blogs 0 29.01.2009 17:05
Часовой пояс GMT +3, время: 04:45.
