Старый 11.09.2011, 19:13   #1
Rahul Sharma: Upload of Fetch-Xml report fails with VB Code - Dynamics CRM
Источник: http://feedproxy.google.com/~r/Rahul...ails-with.html
This is a quick reference to keep things in mind while writing VB code on Fetch-Xml based SSRS reports. You need to avoid using below functions otherwise you wont be able to upload your reports to Dynamics CRM Online.
Currently these are the Namespaces allowed for you to use in your VB code:
Microsoft.VisualBasic.Interaction
Microsoft.VisualBasic.information
Microsoft.VisualBasic.strings
Microsoft.VisualBasic.DateInterval
Microsoft.VisualBasic.dateandtime
Microsoft.VisualBasic.conversion
System.String
System.Object
System.Datetime
System.Timespan
System.Math
System.DbNull
System.Globalization.CultureInfo
System.Text.RegularExpressions.Regex
System.Text.RegularExpressions.Match
In these Namespace following functions are denied:
Acos, Add, Addition, AddMilliseconds, AddMonths, AddSeconds, AddTicks, AddYears, AppActivate, Asin, Atan2, Beep, BigMul, CacheSize, CallByName, capnames, caps, capsize, capslist, Ceiling, Choose, Command, Compare, CompareTo, CompileToAssembly, Cosh, CreateObject, DateString, DayOfWeek, DayOfYear, Days, DaysInMonth, DeleteSetting, DivRem, Duration, E, Empty, Environ, Equality, Equals, Erl, Err, ErrorToString, Escape, factory, Filter, Finalize, Finalize, Fix, FromBinary, FromDays, FromFileTime, FromFileTimeUtc, FromHours, FromMilliseconds, FromMinutes, FromOADate, FromSeconds, FromTicks, GetAllSettings, GetChar, GetDateTimeFormats, GetGroupNames, GetGroupNumbers, GetHashCode, GetObject, GetSetting, GetType, GetTypeCode, GreaterThan, GreaterThanOrEqual, GroupNameFromNumber, GroupNumberFromName, Hours, IConvertible.ToBoolean, IConvertible.ToByte, IConvertible.ToChar, IConvertible.ToDateTime, IConvertible.ToDecimal, IConvertible.ToDouble, IConvertible.ToInt16, IConvertible.ToInt32, IConvertible.ToInt64, IConvertible.ToSByte, IConvertible.ToSingle, IConvertible.ToType, IConvertible.ToUInt16, IConvertible.ToUInt32, IConvertible.ToUInt64, IEEERemainder, InitializeReferences, InputBox, Int, IRR, IsDaylightSavingTime, IsDBNull, Iserializable.GetObjectData, IsError, IsLeapYear, IsMatch, Kind, Lbound, Lset, Matches, MaxValue, MemberwiseClone, Millisecond, Milliseconds, Minutes, MinValue, MIRR, MsgBox, Negate, NextMatch, NPV, Options, Parse, ParseExact, pattern, PI, Pow, ReferenceEquals, Result, RightToLeft, roptions, Rset, SaveSetting, Seconds, Shell, Sinh, SpecifyKind, Subtract, Subtraction, Switch, Synchronized, SystemTypeName, Tanh, TicksPerDay, TicksPerHour, TicksPerMillisecond, TicksPerMinute, TicksPerSecond, Timer, TimeString, ToBinary, ToFileTime, ToFileTimeUtc, ToLocalTime, ToLongDateString, ToLongTimeString, ToOADate, ToShortTimeString, TotalDays, TotalHours, TotalMilliseconds, TotalMinutes, ToUniversalTime, Truncate, TryParse, TryParseExact, Ubound, Unescape, UseOptionC, UseOptionR, VbTypeName, Zero
So, if you are having problem uploading Fetch-Xml reports to CRM Online then it might be a good starting point for debugging.
Follow this blog on facebook and feel free to post your comments / feedback / queries.
Join me on facebook | twitter | linkedin !!!
Microsoft Dynamics CRM Team Blog: Update Rollup 3 for Microsoft Dynamics CRM 2011 Blog bot Dynamics CRM: Blogs 3 03.08.2011 09:11
Rahul Sharma: Microsoft Dynamics CRM 2011 Fetch XML based Custom Reports Blog bot Dynamics CRM: Blogs 0 15.04.2011 00:12
Microsoft Dynamics CRM Team Blog: Parameterizing Fetch Based Reports Blog bot Dynamics CRM: Blogs 0 18.03.2011 20:11
Часовой пояс GMT +3, время: 23:15.
