Вернуться   AXForum > Microsoft Dynamics AX > DAX: За рубежом > DAX in English
Старый 02.08.2011, 15:00   #1
Ahmed Al Abyad is offline
Ahmed Al Abyad
How can I Integrate Windows mobile with Axapta using Webservice
Hi All;
I would like to connect Windows mobile with axapta using C# code, knowing that I can connect to the Axapta using windows application through the following code:-
try
TryWebService.ServiceReference1.Service1Client client = new Service1Client
client.Open(); //this open the axapta which i need it in windows mobile too
catch (Exception ex)
MessageBox.Show(ex.message);
Note: I cant connect to the Axapta through handheld as there is no Service1Client but there is Service which when I take an object from it , it doesn't have function Open() (i.e. there is not client.Open() )
How to connect to Axapta using handheld
Thanks in advance;
Regard's
Старый 02.08.2011, 21:58   #2
Vadik is offline
Vadik
Аватар для Vadik
3,631 / 1853 (69) ++++++++
Hi Ahmed,
There is no single part of AX (neither rich client nor .Net Business connector) which can be installed on WIndows mobile (Dynamics Mobile R.I.P.). Instead, have a look at AIF and .Net Business connector samples on MSDN - for example this one
-ТСЯ или -ТЬСЯ ?
Старый 03.08.2011, 14:50   #3
Ahmed Al Abyad
I don't want to install AX on windows mobile, I want to connect windows mobile to AX that is on windows sever 2008 R2
AX version:-
Kernel version : 5.0.1500.2985
Application Version: 5.0.1500.2985
Solution Version: 5.0.1500.172
This product is licensed to Contoso Entertainment
Serial Number: M3048953
Note: I want to connect handheld with Axapta using webservice not install Axapta on windows mobile
Старый 10.08.2011, 14:53   #4
ZornFire is offline
ZornFire
MS Dynamics AX 2012 R3
Аватар для ZornFire
Oracle
333 / 76 (3) ++++
Ahmed, good day.
If you want connecting to the terminal server, you should first contact your system administrator with the question "whether the connection?", because a lot depends on the server, perhaps it does not include a service charge for this type of connection.
If possible, but it does not work, then read the forums on your mobile device.
"Человек человеку волк, а зомби зомби зомби." (с)
С Уважением, Алексей Кабанов
Старый 11.08.2011, 12:07   #5
cyrus is offline
cyrus
OntargIT
22 / 19 (1) ++
Proper solution for connecting WM terminals to DAX is to use AIF Web services. There are some issues though.
1) WCF is supported only in CF3.5
2) BasicHTTPBinding shall be used. wsHttpBinding is not supported in CF3.5
3) Binding security shall be set to Transport since None is not supported by AIF (it shall know particular web-service user) and TransportCredentialsOnly is not supported by CF3.5
3) IIS shall be configured to support SSL
4) Certificate shall be installed on each consuming device, similar to cross-domain security
If you make security setup properly the connection will be plain simple just like in this example.
Последний раз редактировалось cyrus; 11.08.2011 в 13:00.
aif, axapta, business connector, integration, windows mobile
Dynamics Mobile: How to code your own barcode enabled tasklets (Motorola and Intermec devices) Blog bot DAX Blogs 1 03.06.2014 06:34
emeadaxsupport: Starting Dynamics AX 2009 is launching Windows Installer for Microsoft Axapta 3.0 Blog bot DAX Blogs 0 27.01.2010 13:05
Dynamics Mobile: How to enable barcode scanning on existing Microsoft Dynamics Mobile tasklets Blog bot DAX Blogs 0 07.04.2009 08:05
Ruslan Goncharov: How to get list of all open windows and their names in AX Blog bot DAX Blogs 0 29.12.2007 19:50
Часовой пояс GMT +3, время: 18:25.
