Старый 28.06.2011, 19:11   #1
Dynamics AX Sustained Engineering: Rounding concerns using Breakdown of Voucher in AX 4.0 SP2
Источник: http://blogs.technet.com/b/dynamicsa...x-4-0-sp2.aspx
Problem:
When you enter an AP invoice with multiple line items and choose Breakdown of voucher to split the posting into several lines the amount of lines which have not been selected can be changed.
Resolution:
Make the following changes to \Classes\LedgerJournalSplitPosting\updateLedgerJournal
AmountCur amountToAllocate;
AmountCur highestAmountCur = -1;
RecID ledgerJournalTransRecID;
and
while select tmpLedgerJournalSplitHeader
totalAmountCur = 0;
while select tmpLedgerJournalSplitLines
To:
AmountCur highestAmountCur;
totalAmountCur = 0;
highestAmountCur =0;
Dynamics AX Sustained Engineering: Additional lines appear when opening Breakdown of Voucher form a second time for a journal line with no offset account Blog bot DAX Blogs 0 22.06.2011 08:13
Dynamics AX Sustained Engineering: Announcing Compatibility Certification of SQL Server 2008 SP2 with Dynamics AX Blog bot DAX Blogs 0 18.05.2011 05:16
Dynamics AX Sustained Engineering: Microsoft Dynamics AX 4.0 and AX 2009 are compatible with Microsoft Windows 7 and Microsoft Windows Server 2008 R2 Blog bot DAX Blogs 0 22.09.2009 04:06
Часовой пояс GMT +3, время: 00:37.
