Старый 17.05.2011, 17:11   #1
axStart: Labels in your AIF message
Источник: http://feedproxy.google.com/~r/axsta...xUBvE/Blog.php
Is it possible to get a label in your XML message, default you get the base enum value, but not the label. Yes it is possible. You can join the SRSAnalysisEnums table into your AXD query. Example query from customer site (AXITaxCode is the BaseEnum):
Next override initQuery() method of the AxdBase derived class, add the next:
And here is your message
Note: the SRSAnalysisEnums is filled when data for analysis server is prepared. 0 comments
This is a content summary only. Visit my website for full links, other content, and more!
Последний раз редактировалось Poleax; 18.05.2011 в 09:49. Причина: оформление
emeadaxsupport: Creating an MSMQ message that can be consumed by AX AIF process Blog bot DAX Blogs 0 26.04.2010 19:05
emeadaxsupport: You get the following warning message in BizTalk Server 2006 R2/2009 - The message does not contain a body part Blog bot DAX Blogs 0 18.09.2009 03:13
axStart: Enrich AIF with the power of offline working (roadmap) Blog bot DAX Blogs 0 07.05.2008 15:05
axStart: How to use XSLT in AIF and what’s wrong with empty xml Nodes. Blog bot DAX Blogs 0 27.04.2008 18:07
Pokluda: Outbound web service (AIF) Blog bot DAX Blogs 0 28.10.2006 17:43
Часовой пояс GMT +3, время: 00:51.
