mbsturk: Dynamics AX 2009 Workflow Setup
Источник: http://mbsturk.blogspot.com/2011/02/...low-setup.html
============== Microsoft Dynamics AX 2009 WorkFlow can cause an error when setting up a workflow on Win2008R2. If you receive this error when you run Workflow infrastructure configuration wizard: The request failed with HTTP status 405: Method Not Allowed. Then you should change the Application pool for your workflow (which is by default MicrosoftDynamicsAXWorkflow50) to enable 32 bit applications: ![]() Источник: http://mbsturk.blogspot.com/2011/02/...low-setup.html
