Старый 03.12.2010, 01:13   #1
dynamicsaxtraining: How to check if your variable suit the conditions given in query range
Источник: http://www.dynamicsaxtraining.com/kn...in-query-range
Use inRange methods from Global class
static boolean inRange(str _rangeValue, anytype _value)
Example:
{ str _rangeValue; str _value ; boolean result; ; _rangeValue = ‘200..500’; _value = ‘300’; result = Global::inRange (_rangeValue , _value);}The result variable will be equal to true
axaptapedia: How to count records in a Query Blog bot DAX Blogs 1 27.08.2008 00:38
axaptafreak: Label for query range cannot be modified in AX 5.0 Blog bot DAX Blogs 0 30.08.2007 16:50
axaptafreak: Label for Query Range cannot be modified (still) Blog bot DAX Blogs 2 25.07.2007 10:09
Fred Shen: Date data type in Query Range Value Expression Blog bot DAX Blogs 0 28.10.2006 16:40
Как вытащить информацию о Range из Query raz DAX: База знаний и проекты 1 26.03.2004 11:10
Часовой пояс GMT +3, время: 01:07.
