Старый 25.11.2010, 11:11   #1
workflowax: Security issues in assigning workflow items
Источник: http://workflowax.wordpress.com/2010...orkflow-items/
Recently I’ve been having some issues regarding security rights in workflow in Dynamics AX 2009. We keep on receiving the following error: Stopped (error): Work item could not be created. Insufficient rights for user [USERID].
After some investigation I found the code being executed that checks security when assigning workitems at SysWorkflowEventDispatcher::completeWorkItem() line 63. There are three checks done. But the two that I was interested in were the checks for 1. Menu Item access to the Workflow Document Menu Item specified on the approval/task AOT element and 2. Document access to the record in question.
I checked and confirmed that the user in question had sufficient rights for the Menu Item and Table, yet the workitem still refused to process, however once I gave the user full rights for the security keys to which the table and menu item belonged the workitem was able to assign correctly. E.g. The user had permissions to read and write to the PurchaseReqTable, but didn’t have full rights to the Security Key VendTables, once full rights were given on the security key all worked fine.
This is just my observation of the security and how it practically works out (see link to official documentation below), unfortunately this is not desirable behavior in workflow, as it reduces the security control available to administrators. I was able to overcome the menuitem issue by creating my own menuitem and assigning it a unique security key. However for the PurchReqTable I decided to leave the security as is because of other implications of changing it. If however you have your own custom table that you are working off, you would be able to assign a unique security key to it.
Happy Daxing.
Microsoft documentation on security in workflow : http://msdn.microsoft.com/en-us/library/cc641033.aspx
workflowax: Workflow Wishlist #2 – onDelegateEvent Blog bot DAX Blogs 0 05.10.2010 22:05
workflowax: Why is my yellow workflow bar not displaying Blog bot DAX Blogs 0 20.09.2010 12:05
workflowax: What is a workflow owner used for? Blog bot DAX Blogs 0 01.06.2010 15:05
Ошибка бизнес-процесса Tarasov E Dynamics CRM: Разработка 9 18.02.2010 14:02
Inside Dynamics AX 4.0: The Security Framework Blog bot DAX Blogs 0 31.10.2007 11:40
Часовой пояс GMT +3, время: 07:16.
