AX 2012 R2 инсталляция
AX 2012 R2
Во время синхронизации базы вываливается такая ошибка X++: Microsoft.Dynamics.Ax.Xpp.InfoException: Exception of type 'Microsoft.Dynamics.Ax.Xpp.InfoException' was thrown. at Microsoft.Dynamics.Ax.MSIL.Interop.throwException(Int32 ExceptionValue) at Microsoft.Dynamics.Ax.MSIL.cqlClassIL.callReturn(Int32 rc, interpret* ip) at Microsoft.Dynamics.Ax.MSIL.cqlClassIL.CallStatic(String className, String methodName, Object[] parameters, Type[] types, Object[] varargs, Type[] varargsTypes) at Microsoft.Dynamics.Ax.Xpp.XppObjectBase.StaticCall(String className, String methodName, Object[] parameters, Type[] types, Object[] varargs) at Dynamics.Ax.Application.Debug.assert(Boolean expression) at Dynamics.Ax.Application.DimensionEnabledType.constructForSystemDefinedByTableId(Int32 _viewId, String _viewLabel, Boolean ) in DimensionEnabledType.constructForSystemDefinedByTableId.xpp:line 200 at Dynamics.Ax.Application.DimensionEnabledType.constructForSystemDefinedByTableId(Int32 _viewId) at Dynamics.Ax.Application.DimensionAttribute.getAttributeByHierarchyType(DimensionHierarchyType _hierarchyType) in DimensionAttribute.getAttributeByHierarchyType.xpp:line 116 at Dynamics.Ax.Application.DimensionHierarchy.getHierarchyIdByHierarchyType(DimensionHierarchyType _hierarchyType) in DimensionHierarchy.getHierarchyIdByHierarchyType.xpp:line 88 at Dynamics.Ax.Application.DimensionHierarchy.getSystemGeneratedHierarchyIds() in DimensionHierarchy.getSystemGeneratedHierarchyIds.xpp:line 21 at Dynamics.Ax.Application.DimensionMetadataSetup.Loaddata() in DimensionMetadataSetup.loadData.xpp:line 9 at Dynamics.Ax.Application.SysSetupInstaller.Writealldata() in SysSetupInstaller.writeAllData.xpp:line 19 at Dynamics.Ax.Application.SysSetupInstaller.Run() in SysSetupInstaller.run.xpp:line 7 at Dynamics.Ax.Application.SysSetupInstaller.loadPartitionData(Object[] _c) in SysSetupInstaller.loadPartitionData.xpp:line 3 at SysSetupInstaller::loadPartitionData(Object[] ) at Microsoft.Dynamics.Ax.Xpp.ReflectionCallHelper.MakeStaticCall(Type type, String MethodName, Object[] parameters) at Microsoft.Dynamics.Ax.Xpp.PredefinedFunctions.runAsInvoke(String className, String staticMethodName, Object[] parms, Object[]& exportInfolog) |
