Старый 03.10.2010, 13:59   #1
We all know that “Find as you type” = true is bad for performance. At least I hope so….
But there is another problem with performance.
A lot of people use “Any part of field” to search a field. So, if you want to search for Customer “Deerfield Graphics Company” (customer No. ‘40000′ in W1), you type “Deerfield” and hit enter (hopefully you already have “Find as you type”=false!), NAV sends a <WHERE Name = “*Deerfield*”> to search for it. Even if you have an index on the field “Name”, SQL has to scan the whole index.
If it would be <WHERE Name = “Deerfield*”>, it would be a lot better because SQL can use an index seek which is a lot faster (and you now “Deerfield” is the beginning part of the name).
So best use “Beginning of field” to search.
But if you want to search “*Graphics*”, you need to change it to “Any part of field”? Very annoying!
Answer: No, you don’t need to do it. Just put an * before the name, and your done. E.g. <*Graphics>
BTW: SQL doesn’t use * as wildcard, but %. But for the sake of making it easier to understand, I used * for both NAV and SQL as wildcard.
Читать дальше
Часовой пояс GMT +3, время: 14:45.
