Старый 12.01.2010, 04:44   #1
emeadaxsupport: Warning when loading license file - License value for ID 2024 has not been created (or License value for ID 2025 has not been created)
Источник: http://blogs.msdn.com/emeadaxsupport...n-created.aspx
The name of the module is Dynamics Client for Office.
When you load your AX license file in Microsoft Dynamics AX 4.0 or 2009 and you have bought the module "Dynamics Client for Office" by either licensing for Windows Sharepoint services(2024) or Microsoft Office Sharepoint Server(2025), you get the following infolog warnings:
The reason is because there is no license code in the AX AOT with these names. The license code is generated with the purpose of showing on the code letter what has been bought. If this wasn't added the code letter would not show any Dynamics Client for Office.
You can ignore the warning, the message is only for informational purposes.
emeadaxsupport: You get the following warning message in BizTalk Server 2006 R2/2009 - The message does not contain a body part Blog bot DAX Blogs 0 18.09.2009 03:13
emeadaxsupport: Group policy setting "System Objects: Default owner for objects created by members of the administrators group" is missing on Windows Server 2008 Blog bot DAX Blogs 2 28.08.2009 02:14
emeadaxsupport: License issue when customizing Gantt controls Blog bot DAX Blogs 0 20.08.2009 15:05
emeadaxsupport: AxUpdatePortal.exe does not update Enterprise Portal when not running from an elevated command prompt Blog bot DAX Blogs 0 26.07.2009 15:07
Говорят вышел SP2 для Axapta 3. Кто нибуть что знает на эту тему? soin DAX: Прочие вопросы 10 13.10.2003 10:43
Часовой пояс GMT +3, время: 10:24.
