Старый 01.12.2009, 21:05   #1
How to add all descendant classes to a new project
Источник: http://alexvoy.blogspot.com/2009/12/...lasses-to.html
I bumped into the problem of a class compilation with no licence for X++ source code.
Forward compile option is not enough to make my changes working. Thus I need to export-import all descendant classes as well as the class I changed - FormLetter in my case.
I therefore have to add all these classes to my project. Natural laziness saved me again from this manual work.
I hope this short job inspired by system class SysCompilerOutput and miklenew's job from AXForum will help you in similar situations.
// add to a new project all descendant classes for forward compilation
public static void SISCreateCompileForwardProject(Args _args)
   #AOT
   str                     project = 'SIS_CompileForward';
   SysCompilerOutput       sysCompilerOutput;
   Dictionary              dictionary      = new Dictionary();
   DictClass               dictClass       = new DictClass(className2Id("Formletter"));
   int                     numOfClasses    = dictionary.classCnt();
   ProjectNode             sharedProjects;
   ProjectNode             newProject;
   void addToProjectForwardClass(DictClass _dictClass, Dictionary _dictionary, int _numOfClasses)
   ClassNode           classNode;
   DictClass           dictClassLoop;
   DictClass           childClass;
   int                 i;
       if (_dictClass)
           classNode = infolog.findNode(#ClassesPath + #AOTDelimiter + _dictClass.name());
           if (classNode)
               newProject.addUtilNode(UtilElementType::Class, classNode.name());
               for (i=1; i <= _numOfClasses; i++)
                   dictClassLoop = _dictionary.classObject(_dictionary.classCnt2Id(i));
                   if (dictClassLoop.extend() == _dictClass.id())
                       childClass = new DictClass(dictClassLoop.id());
                       addToProjectForwardClass(childClass, _dictionary, _numOfClasses);
   sharedProjects = infolog.projectRootNode().AOTfindChild('Shared');
   sharedProjects.AOTAdd(project);
   newProject =  sharedProjects.AOTfindChild(project);
   newProject.loadForInspection();
   newProject = newProject.getRunNode();
   addToProjectForwardClass(dictClass, dictionary, numOfClasses);
   newProject.AOTsave();
Старый 02.12.2009, 10:11   #2
kashperuk is offline
kashperuk
Аватар для kashperuk
4,361 / 2084 (78) +++++++++
Хмм. Как же ж это ты без лицензии на Х++ код собрался этот джоб написать и еще и выполнить?
Старый 02.12.2009, 19:15   #3
wojzeh is offline
wojzeh
Аватар для wojzeh
681 / 517 (19) +++++++
а в чём собственно проблема-то? морфикс-то на борту имеется. лицензия на Х++ даёт возможность править классы без утомительного экспорта-импорта
Felix nihil admirari
Последний раз редактировалось wojzeh; 27.10.2019 в 19:35.
Dynamics Mobile: How to code your own barcode enabled tasklets (Motorola and Intermec devices) Blog bot DAX Blogs 1 03.06.2014 06:34
chrisfie: Project Server 2007 TechNet Webcasts recordings and decks Blog bot DAX Blogs 0 21.07.2009 10:05
Передача функции в качестве параметра lemchey_white DAX: Программирование 20 21.01.2008 22:51
axStart: How to work with big projects with multi add-ons Blog bot DAX Blogs 0 30.12.2007 16:30
Часовой пояс GMT +3, время: 08:04.
